How To: 997C2S Strut/Spring Removal/Installation
Old Sep 7, 2008 | 12:33 PM
Fast997S's Avatar
Fast997S is infamous around these parts
997C2S Suspension/Strut Removal and Installation
I installed new PS10's on my C2S and had some friends ask me how I did it, so I thought I would post. It took my son and I about 1 hour per corner to do the job. It looks like a lot of work, but really wasn't too bad. Don't forget to use all the normal safety precautions when working while car is on jacks.
Note: Refer to photos while reviewing instructions.
Front
1. Remove ABS and Brake sensors using 10mm. Note orientation.
2. Remove brake line bracket bolt (10mm) from hub and brake line from caliper (10mm). Slip rubber cap on brake line so fluid won’t leak out.
3. Remove Steering knuckle (so strut can swing around). Use 18mm socket (may need T40 back-up; also may need to break loose with slight nudge from 5 lb sledge)
4. Remove lower front arm bolt at hub (turn strut to access). Use 21mm box, 18mm socket. Pull from hub arm but do not completely remove.
5. Remove stabilizer arm bolt (this will loosen strut for removal). Use 18mm socket (may need T40 back up or needle nose vice grip on ball joint side)
6. Remove upper strut bolts in trunk using 13mm socket.
7. Pull out strut
8. Support hub with wire (see photos)
Note: Remove suspension position sensor on left side only (small plastic arm) w/ 10 mm
To install, reverse of above
Don't forget to bleed the front brakes when you're all done
Rear
1. DO NOT remove brake lines
2. Remove rear lower control arm at ball joint (toe-in adjst arm). Use 18mm, may need T40 backup.
Ball joint may need to forced out with either a ball joint remover, or else a slight nudge with a 5lb sledge (but you MUST support mount from bottom with a piece of wood if you do this). Push arm down and back from hub. This arm needs to be removed at hub so that lower shock mount bolt can be removed.
DO NOT remove or mess with other end of arm (adsjt. end).
3. Remove upper rear control arm bolt using 16mm socket/18mm box (this lets hub drop down so you can remove strut). DO NOT remove other end at hub.
4. Remove bolt from lower front arm at hub (like #4 above).
5. Remove lower shock bolt using 18mm box and 16mm socket.
6. Remove stabilizer bolt from hub arm using 16mm socket (may need T30 backup).
7. Remove upper bolts, 15mm socket.
Disassembly of Strut: The springs are NOT preloaded much so you don’t need a spring compressor. Front strut bolt comes of easily. I had to put upper washer on rear strut in vice (while it’s on strut) so piston rod wouldn’t turn. New springs, like Eibachs, need to be compressed; Ps10’s don’t. Don’t forget to mark orientation of springs and mounting hardware before taking strut apart.
Photos:
Front
Front close-up
Rear
Rear close-up
Completed Installation
Old Sep 7, 2008 | 03:22 PM
JoeyM's Avatar
JoeyM is infamous around these parts
awesome, thanks!
Old Sep 17, 2008 | 09:46 PM
Fast997S's Avatar
Made a few changes.
Old Aug 18, 2012 | 12:19 PM
gray911's Avatar
gray911 has much to be proud ofgray911 has much to be proud ofgray911 has much to be proud ofgray911 has much to be proud ofgray911 has much to be proud ofgray911 has much to be proud ofgray911 has much to be proud ofgray911 has much to be proud ofgray911 has much to be proud of
Can I just remove the caliper and not the brake line to spare me from needing to bleed the brakes? Thanks.
Old Aug 19, 2012 | 12:17 AM
solidst8's Avatar
solidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud of
Brake line does not need to be removed. Hang the caliper or rest it on an inverted bucket in the wheel well. Just make sure the brake line is not being stretched. You'll be ok.
Old Aug 19, 2012 | 12:50 AM
kkswow12's Avatar
kkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nice
sub'd
Old Aug 19, 2012 | 05:26 AM
gray911's Avatar
Thank you. I just needed to confirm.
Old Jan 7, 2017 | 07:59 AM
John997s's Avatar
John997s is infamous around these parts
Does anyone have the torque value for the upper controle arm bolt?
undefnd
16
Aug 26, 2015 07:59 PM
Mika_Hakkinen
Dec 22, 2005 12:30 PM
Mika_Hakkinen
Dec 11, 2005 04:29 AM
