H & R spacers Need Help!!!
Old Oct 23, 2008 | 11:50 AM
911bobby's Avatar
911bobby is a splendid one to behold911bobby is a splendid one to behold911bobby is a splendid one to behold911bobby is a splendid one to behold911bobby is a splendid one to behold911bobby is a splendid one to behold911bobby is a splendid one to behold
Hello Everyone,
I just picked up the Bilstein Damtronics And H & R Sway Bars from Dan at Vivid (thx for the hook up bro). I have the 2008 C2S with 19" Turbo Wheels 8x19 fronts (235/35ZR19 pS2) and 11x19 rears (295/30ZR19 ps2). I will be getting the H & R spacers but the golden question is which size spacers? and how long of the bolt do i need? Also will i have to change out my lug nuts? And if i can get some infor as to what height to lower and how neutral or stiff to attache the sway bars??? Thanks in advance. Its a DD and i have no plans to track it yet?
Old Oct 23, 2008 | 01:18 PM
AP 997S's Avatar
AP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud of
The 'standard' lug bolt has a shank of approx. 30 mm.
Here's the 'typical'. If you add 15 mm spacers on the rear you need at least 45 mm bolts. If you add 7 mm spacers on front you need at least a 37 mm bolts. Of course off the shelf bolts don't come in those exact lengths so get the nearest one (on the long side).
I believe the rule of thumb is to have a minimum of 6 to 8 threads in the hub for safety purposes (I might be a bit off here). Hopefully someone will pipe in w/ the correct number.
Old Oct 23, 2008 | 02:14 PM
NorthVan's Avatar
+1
But I think that the Turbo wheels might have a different offset when compared to a other stock C2S wheels. You may be at the outside of your fenders now.
BTW enjoy your Damptronics and Sway bars, they are awesome.
Old Oct 23, 2008 | 02:20 PM
AP 997S's Avatar
Originally Posted by NorthVan997C2S
+1
I think you're right about turbo wheel offsets! I was thinking he had lobsters. I failed to read the post correctly.
Old Oct 23, 2008 | 06:18 PM
911bobby's Avatar
Thx guys,
you might be right about the turbo wheels that might be the reason guy none off the vendors can really give me an exact bolt size??? anybody out there turbo wheels that know the specs??? any advice would be appreciated!!
Old Oct 23, 2008 | 06:48 PM
AP 997S's Avatar
On a narrow body (ie. 997 or 997S) the turbo wheel might already sit flush w/ the fender edge and thus no spacer is required.
Do a search or ask around the various forums for the answer. There are plenty of narrow bodied 997's w/ turbo wheels.
The bolt length question is simple. Just add the spacer width to the existing bolt length (shank only) and you've got the length required.
Good Luck . . . . . . .
Old Oct 23, 2008 | 08:43 PM
911bobby's Avatar
first of all thx again guys! i guess the best bet is to put in the bilstein, sway bars, and get a better idea if i would need the spacers if any then go from there. One more question should i lower the front more then the back?
Old Oct 24, 2008 | 05:52 AM
jhbrennan's Avatar
Originally Posted by 911bobby
Thx guys,
If your C2 came with the Turbo wheel option you probably already have the correct offset since Porsche does make a narrow body version of the Turbo wheels. Usually vendors who sell spacers (like Wheel Enhancement) will sell you the correct size bolt.
Old Oct 24, 2008 | 10:14 AM
911bobby's Avatar
thx bro i will give them a call today!! thx everyone
Old Oct 24, 2008 | 10:37 AM
911bobby's Avatar
WOOOOOOOOWWWWWWWWWW!!!! i just got off the phone with dave at wheel enhancement and apparently there is no lug nuts or wheel locks for this type of extension?????????? why is that no one makes these locks or nuts??????
Old Oct 24, 2008 | 11:50 AM
jhbrennan's Avatar
Not sure what size spacers you were considering but go to these links and you'll see spacers and lug bolts. You probably won't find wheel locks though, which is no big deal since if someone wants your wheels, the wheel locks probably won't help.
http://shop.fvd.de/us/en/Porsche-0/-...5/Spacers.html
http://shop.fvd.de/us/en/Porsche-0/-...he_Tuning.html
Old Oct 24, 2008 | 12:19 PM
NorthVan's Avatar
Have your installer install them to ROW height. I had mine set to that height, works really well.
Old Oct 24, 2008 | 03:14 PM
808c2s's Avatar
808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !
You may try calling or emailing Ralph Boothe at www.boothedesign.com
Old Oct 24, 2008 | 04:47 PM
911bobby's Avatar
thx all for your help!! i ordered mine with dave & Alan at wheel enhancement since they were able to tell me exactly the size and bolt extension for me.
H & R 1495716 7mm DR spacers (2)
H & R 1455206 14mmx 1.5x52mm lug bolt
H & R 30957161 15mm DR spacers (2)
H & R 1456006 14mmx 1.5x60mm lug bolt
Done Hopefully everything will be complete by next weekend!! Will post before and after pictures as soon as i can!!!
NorthVan997C2S what do you mean by ROW height?
Old Oct 24, 2008 | 05:40 PM
808c2s's Avatar
He meant "Rest Of the World" settings. I think it's 20mm drop along with the accompanying alignment settings. Correct me if I'm wrong NorthVan
