997 reliability - anyone had maintenance issues?
Old Feb 17, 2009 | 07:05 PM
Higher750's Avatar
Higher750 is infamous around these parts
Any maintenance concerns outside of regular service? Any specific trouble areas popping up as some of the earlier years get more miles on them?
Old Feb 17, 2009 | 07:52 PM
Kurt_OH's Avatar
Kurt_OH is infamous around these partsKurt_OH is infamous around these parts
Try searching on IMS (intermediate shaft) and RMS (rear main seal), for starters.
Old Feb 17, 2009 | 08:50 PM
NorthVan's Avatar
Nothing on my car, solid as a rock.
Old Feb 17, 2009 | 09:10 PM
yrralis1's Avatar
Both 997S cars were flawless but were sold before 10K miles .
Modded turbo is flawless too .
On the whole - as reliable as my Honda (3rd car) but a lot more fun to drive.
Old Feb 17, 2009 | 09:43 PM
500's Avatar
500
500 is infamous around these parts500 is infamous around these parts
2007 997S bought new.
Had several relatively common 997 issues:
Loose front suspension bolt
Battery cable issue
A few rattles which I repaired and others which required a dealer visit
Very squeaky rotors replaced at 1500 miles under warranty
Clutch chatter but they all seem to have a small degree of this
Paint on ash tray coming off replaced under warranty
From a reliabilty standpoint it's been very solid, the engine is strong and uses very little oil. Just wish the six speed cars had an aux oil cooler.
Old Feb 17, 2009 | 09:53 PM
cibergypsy's Avatar
cibergypsy is a jewel in the roughcibergypsy is a jewel in the roughcibergypsy is a jewel in the rough
+1 in my case too!
Old Feb 18, 2009 | 04:12 AM
bhart192's Avatar
bhart192 is infamous around these parts
rms
replaced RMS @ 18K ,
Old Feb 18, 2009 | 08:20 AM
Mr. B's Avatar
Mr. B is a name known to allMr. B is a name known to allMr. B is a name known to allMr. B is a name known to allMr. B is a name known to allMr. B is a name known to all
Batt. & Alt.
Had the battery & alternator fail last October.
Dealership replaced both under warranty.
Replacement alternators are not new, they re-manufactured.
My re-manufactured alternator failed in January and dealership replaced it under warranty.
Aside from these issues, the car has been fine.
Mr. B
Old Feb 18, 2009 | 10:21 AM
mstams's Avatar
mstams is infamous around these parts
What were the symptoms?
Old Feb 18, 2009 | 11:08 AM
mickfluff's Avatar
mickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant futuremickfluff has a brilliant future
whats this?
Loose front suspension bolt?
I ask as I hear a strange noise (like a squeak, rub, something a little loose) when I turn my steering wheel, is that the symptoms, anyway one can self diagose? I added coil overs and this started a little after so fear dealer will blame this when in fact could be something else or what you mentioned above, thanks for any advise...
Battery cable issue
Old Feb 18, 2009 | 12:05 PM
Dave07997S's Avatar
Dave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant future
2007 997S coupe bought new with 11k miles on the clock...
The car has been flawless other than the driver side TPMS going whacky on me. Every morning it tells me flat tire, I drive 2 miles and then it shows 75lbs of pressure. I need to take it in..
Dave
Old Feb 18, 2009 | 02:30 PM
EJ-997's Avatar
EJ-997 is infamous around these parts
service
my 08C2s had a defective low tone horn.
Old Feb 18, 2009 | 02:45 PM
printemps2001's Avatar
printemps2001 is infamous around these parts
I just had my 20k service yesterday. It was the car's second trip to the dealer (first for a 10k service). Other than all the tires I seem to buy, the car has cost me exactly $500 for routine maintenance and nothing else. The only warantee work I have had done is a blown fuse for the power outlet (replaced with a 15 amp) and a wiper arm plug replaced (it mysteriously went missing). The car has been completely trouble free. It is a year round daily driver, seeing hot, cold, stop-and-go traffic as well as track days.
Old Feb 18, 2009 | 06:43 PM
lakerholic's Avatar
lakerholic is a splendid one to beholdlakerholic is a splendid one to beholdlakerholic is a splendid one to beholdlakerholic is a splendid one to beholdlakerholic is a splendid one to beholdlakerholic is a splendid one to beholdlakerholic is a splendid one to behold
Battery cable issue
This is interesting as the rotors on my 06 997 S intermittently squeak A LOT. The brakes are all +80% life left, so I didn't know what to do. Good to know that a good dealer will address this.
I also had some issues with plastic peeling on my center console, ignition surround and light surround -- all were fixed, without issue, under warranty (and I'm the second owner of my car and brought it to CA from out of state). Rattles were also fixed under warranty, and under the care of a tech who really gave a crap (unlike my experiences with rattles in previous Lexus, Audis and BMWs...)
It's a pretty reliable car IMHO... just take good care of it, and it will do the same for you in spades.
Old Feb 18, 2009 | 06:52 PM
Bara's Avatar
Bara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant future
good to hear the positives.
