is there a lock when using spacers?
Old Apr 28, 2009 | 05:59 PM
Bara's Avatar
Bara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant future
how do you lock your wheels when using longer bolts?
Old Apr 28, 2009 | 09:42 PM
NorthVan's Avatar
I don't have a lock with my spacers. I find it is a PIA and if someone really wants your wheels they will get them!
Old Apr 28, 2009 | 10:12 PM
Lockie's Avatar
Lockie has a brilliant futureLockie has a brilliant futureLockie has a brilliant futureLockie has a brilliant futureLockie has a brilliant futureLockie has a brilliant futureLockie has a brilliant futureLockie has a brilliant futureLockie has a brilliant futureLockie has a brilliant futureLockie has a brilliant future
I also agree that it is a PIA . My spacers came with the longer bolts including one "lock" bolt per wheel. I am going to get rid of the"lock" bolt
Old Apr 28, 2009 | 11:32 PM
yrralis1's Avatar
New bolts (exception /titanium) are not too expensive .
Old Apr 29, 2009 | 06:25 AM
jhbrennan's Avatar
If you really want longer locking lug bolts you can get them here
http://e-partssales.com/Merchant2/me...de=996361XXX02
or buy 4 of these
If you're using any thickness greater than 7mm you probably won't find any "lockers".
Old Apr 29, 2009 | 07:58 AM
Paul540/m3's Avatar
Paul540/m3 is infamous around these partsPaul540/m3 is infamous around these partsPaul540/m3 is infamous around these partsPaul540/m3 is infamous around these partsPaul540/m3 is infamous around these parts
If you are dead set on getting locks, then you can research and find a car with longer stock bolts but ensure that the threads are the same and that the head style is the same as well (flat vs. concave). I had to do this with a BMW and had luck contacting McGard (www.McGard.com).
They may be able to point you in the right direction. Tell them what car you have and they can see what style the stock wheel locks are and then find a longer version of them (if the exist).
Old Apr 29, 2009 | 04:32 PM
Bara's Avatar
thanks guys. im thinking northvan is right.
Old Apr 29, 2009 | 06:38 PM
Sev's Avatar
Sev
Sev is infamous around these partsSev is infamous around these parts
I'm running the OEM Porsche bolts and locks that are made for the 5mm spacers on my H&R 7mm spacers. I measured them and they are about 7 mms longer than the stock ones...
Old Apr 29, 2009 | 07:25 PM
Bara's Avatar
the longer bolts are under greater stress and probably need extra 'bite' to properly secure. i dont think its a 1 to 1 ratio of spacer thinckness to bolt lenght.
you probably wont have problems but i'd rather get the h&r bolts for the 7mm
Old Apr 30, 2009 | 06:23 AM
Sev's Avatar
Sev
H&R and all other spacer manufacturers recommend an increase of bolt length of the same thickness of the spacer. Porsche, being a conservative OEM manufacturer, goes overkill as usual...
NIKAS
Aug 20, 2019 07:53 PM
Bmw M3 Guy
Feb 21, 2018 09:29 AM
keeperofbeasts
11
Apr 3, 2017 10:53 AM
Wheeler
Sep 22, 2015 08:02 PM
lokmeup
Sep 9, 2015 09:24 PM
