PDK launch control, any problems yet?
Old Sep 20, 2009 | 07:51 PM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
Originally Posted by theufoguy
Steps:
1 - Activate Sport Mode Plus (automatic)
2 - Press the brake down fully
3 - Then press the accelerator down all the way QUICKLY and hold it there till you hear the car beep and you see the words "LAUNCH CONTROL ACTIVE" in the instrument lcd display. The RPMs should be at around 6500.
4 - Release the brake as fast as possible and keep the accelerator floored
5 - Hold on and try not to look like
Make sure you press the throttle all the way down past the kick down button.
This is all in the owners manual.
Old Sep 20, 2009 | 07:53 PM
mdrums's Avatar
****ATTENTION**** on the 997.2 cars Launch Control is ONLY FOR PDK CARS WITH SPORT CHRONO PLUS.
This DOES NOT apply to 6speed manuals.
Old Sep 20, 2009 | 07:55 PM
sayboy's Avatar
sayboy has a reputation beyond reputesayboy has a reputation beyond reputesayboy has a reputation beyond reputesayboy has a reputation beyond reputesayboy has a reputation beyond reputesayboy has a reputation beyond reputesayboy has a reputation beyond reputesayboy has a reputation beyond reputesayboy has a reputation beyond reputesayboy has a reputation beyond reputesayboy has a reputation beyond repute
If you try it, keep in mind your accelerator must be floored and activating the kick-down detent button under the pedal. If you have done everything correctly then "Launch Control Active" illuminates in the gauge display as the engine sings its intoxicating song of joy.
Then sidestep the brake and revel in the pleasures of engineering excellence!
Old Sep 20, 2009 | 07:57 PM
sayboy's Avatar
Posted 4 minutes apart. Haha... great minds think alike eh Mike?
Old Sep 20, 2009 | 09:19 PM
PersianGodFatha's Avatar
PersianGodFatha is a glorious beacon of lightPersianGodFatha is a glorious beacon of lightPersianGodFatha is a glorious beacon of lightPersianGodFatha is a glorious beacon of lightPersianGodFatha is a glorious beacon of light
so do you push the PSM button and turn it off, or do you leave it alone and leave it on??
Old Sep 20, 2009 | 09:23 PM
camhabib's Avatar
camhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond reputecamhabib has a reputation beyond repute
Originally Posted by Sev
It must be slipping the clutch at those kind of rpms. There will definately be some serious wheel hop if the clutch engages suddenly like in on a 6 speed clutch drop or sidestep...
Seeing as how everything is a preprogramed computerized system, is it possible that the car adjusts power to prevent any slip instead of simply adjusting how fast the clutch lets out?
Old Sep 21, 2009 | 05:52 AM
utkinpol's Avatar
utkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond repute
If engine is almost at redline - unlikely you can do much to adjust anything - you just hit your tranny with 300+ horses directly one way or another.
Old Sep 21, 2009 | 06:28 AM
sayboy's Avatar
Leave it On.
The article in the car magazine was wrong when they said to turn PSM off.
Sport Plus+Left foot brake+Right foot accel flat to floor+Release brake= voila' Launch Control
Old Sep 21, 2009 | 04:53 PM
Sev's Avatar
Sev
Sev is infamous around these partsSev is infamous around these parts
Originally Posted by adias
You are not trying to launch a 997.1 like a PDK LC, are you? If you are, watch the clutch/semi-axle/diff damage...
In any case... a 911 is not a dragster. To each his own.
Lets not jump to conclusions. I was talking "in theory"...
Old Sep 21, 2009 | 05:00 PM
Sev's Avatar
Sev
Interesting question... I would think it is more likely a clutch slip but in theory I guess it would be possible that engine power is controlled during the launch to reduce damage...
I would be interested in reading more about this if anybody has more info. I don't have a PDK car, I don't drag race, just curious about mechanical\electronic stuff..
Old Sep 29, 2009 | 11:58 AM
kiet420's Avatar
kiet420 is a splendid one to beholdkiet420 is a splendid one to beholdkiet420 is a splendid one to beholdkiet420 is a splendid one to beholdkiet420 is a splendid one to beholdkiet420 is a splendid one to beholdkiet420 is a splendid one to behold
Steps:
That's how I do it! I've done it 5 times or so and loved it, need to have enough road so that you can shift through the gears.... The wife couldn't stop giggling!
jyupitt1
Aug 31, 2015 12:58 PM
jmorgan911
Aug 28, 2015 10:24 AM
Jaytaylor10485
Aug 28, 2015 06:25 AM
MrMiggy
Aug 21, 2015 06:55 PM
