Infant car seat in the 997
Old Oct 18, 2009 | 09:15 PM
GIjbop's Avatar
GIjbop is infamous around these partsGIjbop is infamous around these parts
Infant car seat in the porsche 997 can be done!
after a fair bit of searching in different forums..there was not much info out for finding and installing a forward facing Canadian Infant car seat in the rear seat of a porsche 911. (The porsche infant car seats are NOT available in Canada. I think they are not approved for use here)
So for those who have a partner who requests that the new car needs to be able to fit a car seat...well..the 997 can do it...heres what worked for me. Might save you hours of web surfing and trial and error.
Steps
#1) only seat i found (only searched toysrus) was the SAFETY FIRST infant car seat named AIR PROTECT. Its got a narrow enough base to just fit onto the rear seat (which is concave shaped). Cost $300 CDN. It just came out i think...lucky me. (There may be more car seat options in the USA).
#2) Behind the rear seats, at the top, there is a rear anchor tethor hidden under the carpet. The carpet is already precut, except for one area which needs an Exactoblade to cut about 1cm. AFter that it lifts up and you can see the anchor underneath.
#3) I removed the rear seat cushion. This is secured by velcro only so ..easy job. I tried the seat with and without the seat cushion and i think the car seat sits lower and is more stable without it and i dont have to worry about damaging it.
#4) The rear seat belt receptacle needs to be adjusted to face more vertical. This is because it faces forward originally and can not provide enough tension to hold the car seat back with the belt. To adjust you need to first remove the plastic cover at the base of the seat belt receptacle by pulling it off..it just snaps off. This exposes the Screw head that secures the receptacle. Then you need to use a SOCKET WRENCH to loosen the Screw Head and then rotate the receptable upwards. Then screw it back down super tight!!!
#5) place rolled up towel on the base of the rear seat for added support.
#6) install car seat as usual.
Quite secure in my opinion.
Good luck...theres not much room in the back and i had a sore neck after installing hahaha.
Note son is 20 mo old. He is 50%ile in height. He likes to put up his feet against the rear seat on the carbon fibre..but luckily i bought this tinted window sunscreen (for my other car) which also sticks well on the carbon back and protects it. Also, my son really like to be able to LOOK FORWARD through the GAP in the BUCKET SEATS so he can see ahead (when there is no one in the front passenger seat).
my wife in the passenger seat is 5'5" and she is fine with the leg room.
Worst part was....i scratched my door afterwards. When i closed the door at the end of the hard work... my watch came in contact with the paint!! (ive never done that to any car before!).
Well hope this helps out those who were debating on getting a 911 because of the car seat issue.
Old Oct 18, 2009 | 10:29 PM
lakerholic's Avatar
lakerholic is a splendid one to beholdlakerholic is a splendid one to beholdlakerholic is a splendid one to beholdlakerholic is a splendid one to beholdlakerholic is a splendid one to beholdlakerholic is a splendid one to beholdlakerholic is a splendid one to behold
Awesome write-up!
Glad I'm not the only one who found the seat belt buckle trick! Definitely makes a difference, and makes the car seat stay seated properly, when rotated to the verticle position.
Again, great job and your car looks beautiful in Meteor.
Enjoy it in good health!
JoeShark's Avatar
JoeShark has much to be proud ofJoeShark has much to be proud ofJoeShark has much to be proud ofJoeShark has much to be proud ofJoeShark has much to be proud ofJoeShark has much to be proud ofJoeShark has much to be proud ofJoeShark has much to be proud of
Great post, write-up, and pictures.
Old Oct 19, 2009 | 08:54 AM
John McLane's Avatar
John McLane is a splendid one to beholdJohn McLane is a splendid one to beholdJohn McLane is a splendid one to beholdJohn McLane is a splendid one to beholdJohn McLane is a splendid one to beholdJohn McLane is a splendid one to beholdJohn McLane is a splendid one to behold
Nice, I got some similar problems on my installation..
For reference, Britax makes the Porsche seats, the smaller is the roundabout and the bigger is the Boulevard (I think, not a 100%)
Did you consider taking the vertical part back seat out to add some AP room? I've read people doing both with different results.
For the guys with convertibles, Porsche do not recommend child seat on the back, anyone tried?
Old Oct 19, 2009 | 09:44 AM
JoeShark's Avatar
I've got the Britax Roundabout in the back of my Cab and it works pretty well. Where did you hear about Porsche not recommending seats in the back as I'd be pretty curious about that.
Old Oct 19, 2009 | 09:59 AM
You're right, my quote was not specific. It's the tethered anchor that appears to be available for targa and coupe only, but I never checked on cabs to see if that's true. If one uses the seat belts it should be fine then. The only restriction that I saw in the manual is to use child seats on sport bucket seats.
Old Oct 19, 2009 | 10:14 AM
P Diddy's Avatar
P Diddy is a glorious beacon of lightP Diddy is a glorious beacon of lightP Diddy is a glorious beacon of lightP Diddy is a glorious beacon of lightP Diddy is a glorious beacon of light
I like those CF seats
Old Oct 19, 2009 | 10:20 AM
JoeShark's Avatar
Thanks for the clarification as you got me worried a bit there. My little guy would be bummed if he didn't get to ride in the back anymore.
Old Oct 19, 2009 | 06:44 PM
mshanler's Avatar
mshanler has a spectacular aura aboutmshanler has a spectacular aura aboutmshanler has a spectacular aura about
MY 997 '05 S Cab doesn't have a rear tether.
Old Mar 29, 2010 | 11:56 AM
mxs508porsche's Avatar
mxs508porsche is infamous around these parts
which Safety first airprotect car seat did you use? it looks like there are a few different models. thanks
COBB Tuning
Jan 1, 2025 09:02 AM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
TrackOne
Aug 20, 2015 12:56 PM
pwdrhound
Aug 20, 2015 05:54 AM
