Did I overfill the oil ??
Old Feb 10, 2010 | 01:22 PM
echere88's Avatar
echere88 is infamous around these parts
This morning I took the measure of the oil for my 3200 miles 977.2 S. The oil measurement showed the level at low line. So I read the manual, and the manual states that each "tick" is about 0.5 qt. Then I figured that I have 3 tick to fill, so I pulled 1 qt of oil in it, and i will replenish the oil but not to exceed the maximum level. After I pulled 1 qt in the engine, I took the measurement again. To my surprise, the level showed right at maximum line. I was expecting a tick lower than the max.
How do I know if I overfilled the oil? If I overfilled, will the level showed going above the max line in the indicator? Any advice is appreciated.
Old Feb 10, 2010 | 01:32 PM
Scott997's Avatar
Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !Scott997 Is a GOD !
It's always a good idea to never fill more then half a quart at a time. I usually like to have my level right in the middle or 3/4.
If it makes you feel any better on my last service from the dealer on my 997.2 it was filled up to the max level also (to my suprise).
Your most likely fine.
Old Feb 10, 2010 | 01:33 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Mine comes back from the dealer after a fill at the top line and with filter they put in 10 quarts. They assure me that they are not over filling it. Based on what you said the reading was when you started, down 3 tics, you should be fine and the top line means you're full not necessarily over full.
Old Feb 10, 2010 | 03:33 PM
wa1l1in's Avatar
wa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of lightwa1l1in is a glorious beacon of light
turn engine off wait 5 mins.. turn back on and check.. should go down..
wait till the "oil light" comes on. then add a qt then its' perfect at the top again... the system is finicky for sure.. just waiting 5 mins and turning back on and rechecking changes the level by 1-2 bars..
Old Feb 10, 2010 | 04:10 PM
///MJFDDS's Avatar
///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute
You may possibly see some white smoke on startup in an event of an overfill. It is possible to drain some in the event that you feel you may have overfilled. Pull the filter housing and pour out the oil that is in it. That should be enough for a slight overfill.
Old Feb 10, 2010 | 04:18 PM
NorthVan's Avatar
Good Advice
Your car should also be on level ground, any angle can affect the actual reading.
Old Feb 10, 2010 | 04:24 PM
Dave07997S's Avatar
Dave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant future
Exactly, that's what I do. It's been 6k miles since my oil change (going to do it next week) and I needed to add some oil I was just on the last bar before the low oil warning. I added .5 qt. and I was just back at the max line. Took her for a drive and let her sit for 10 minutes rechecked and it actually was one bar from the top fill.
Dave
Old Feb 10, 2010 | 05:57 PM
Scott997's Avatar
We are very fortunate on how easy it is to check our oil! It still find it so amazing.
Old Feb 10, 2010 | 07:30 PM
rvhpno80's Avatar
rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !
+1 on that, i just got my oil change as well, and it was to the max when i checked it, I believe your fine aswell......keep us posted...
Old Feb 10, 2010 | 07:38 PM
solidst8's Avatar
solidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud of
If you overfill, the top "short" bar above the max line will blink. Same goes if you are below the min line, the bottom short bar will blink. It's in the manual, I think.
Old Feb 10, 2010 | 07:55 PM
rvhpno80's Avatar
very good point, i have seen it blink when it is too low...never seen it blink when i filled it up.....
Old Feb 10, 2010 | 09:02 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
I've never heard this before. I would so prefer a dipstick. Most bemoan this finicky and inexact way of performing a basic engine check. You really cannot measure better than within .4 of a qt. At the very least, Porsche could include a gauge to verify that the car is "on the level." Oh well, progress
ECS Tuning - BMW
Sep 22, 2015 08:34 AM
ECS Tuning - BMW
Sep 22, 2015 08:00 AM
ECS Tuning - BMW
Sep 22, 2015 07:49 AM
ECS Tuning - BMW
Sep 22, 2015 07:31 AM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
