Brake Job
Old Apr 10, 2010 | 06:59 PM
artman's Avatar
artman is infamous around these parts
Brake Job
How much do u guys pay for a brake job, is 1600 reasonable for all four brakes and rotors?
Old Apr 10, 2010 | 07:26 PM
adias's Avatar
adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !
It sounds high to me.
Old Apr 10, 2010 | 08:43 PM
NorthVan's Avatar
Are you doing front and rears? What car do you have?
Old Apr 11, 2010 | 10:23 AM
RonCT's Avatar
RonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond repute
Take a look at the Suncoast parts website. I think front rotors are now $335 and rears still $280. Pads are less. Total parts are in the $1000 range with new sensors, etc. So it appears they are at about $600 for parts profit (above the deep discount of Suncoast) and labor. Not outrageous, but also not great. I had a shop recently quote me $200 to change out rotors, and therefore pads, etc. had to come out.
Old Apr 11, 2010 | 11:57 AM
NorthVan's Avatar
That is assuming it is both front and rear, and a S.
As for the labour, it is an easy swap, and as a DIY should be about 1-1.5 per axle (or faster if you have done it before).
Old Apr 11, 2010 | 12:08 PM
utkinpol's Avatar
utkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond repute
As for the labor, it is an easy swap, and as a DIY should be about 1-1.5 per axle (or faster if you have done it before).
I never did it on my car ever - at first try pads replacement was 15min per corner, If U would have to disconnect calipers and swap rotors - may be it would add 15 min more top.
$130 per hour rate - let`s say 2 hours top - $300 max for labor. So question is what parts were ordered for that 'brake job' to make up for rest of $1300. Some rotors may run that high.
Old Apr 11, 2010 | 12:20 PM
socalsteve's Avatar
socalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to allsocalsteve is a name known to all
Where are you getting this quote from? A stealership or an independent shop?
Take 30% off for an independent shop (approx.).
Please inform me as I am in LA as well.
Thanks,
Steve
Old Apr 11, 2010 | 04:35 PM
socalsteve's Avatar
Originally Posted by Rennsport-1
I have pads and rotors with 2k on them for a smoking deal. Let me know if you are interested. Your welcome to shoot me a pm.
Sent you a PM regarding purchase.
Thanks,
Steve
Old Apr 11, 2010 | 07:56 PM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
Carrera or Carrera S????
For an S like RonCT said front and rear rotors will be around $610, pads will be $400, you can reuse the sensors if you did not activate them. Hardware will be a few buck if you replace the pin, cotor key, anti-squel stuff.
$1600 is OUTRAGEOUS! More like $1200 most with labor but the job is soooo easy.
Old Apr 11, 2010 | 08:32 PM
ryem3's Avatar
ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !
Will the rotors typically last 2 sets of pads? My rear pads are low and I'm wondering if I will need rotors too. Not sure if I trust an indi or even my dealer to tell me if the rotors are within spec!
Old Apr 11, 2010 | 08:53 PM
neil.schneider's Avatar
neil.schneider has a spectacular aura aboutneil.schneider has a spectacular aura about
How many miles on on these cars that need brakes?
Old Apr 11, 2010 | 09:51 PM
Alnoaimi's Avatar
Alnoaimi is infamous around these parts
Any DIY explination? My car needs both front and rear as well as the rotors. 48.000 KM=30.000 Miles
Old Apr 11, 2010 | 10:01 PM
NorthVan's Avatar
This should help, also do a search, as there are other threads
https://www.6speedonline.com/forums/...onversion.html
Old Apr 14, 2010 | 12:44 AM
Alnoaimi's Avatar
Thank u
Old Apr 14, 2010 | 06:59 AM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
Yes the rotors should last 2 sets of pads.
Normal change interval is about 30k miles for a car that isn't tracked.
$1600 is outrageous. If the rotors have only seen one set of pads, then why are you replacing them? Regardless, it's a simple DIY job to replace the pads and rotors. Even with basic skills you should be able to do a wheel in a half hour - 45 mins.
Rguy
Apr 12, 2020 11:11 PM
Rockinc1
Sep 30, 2015 06:44 PM
GSP
Sep 9, 2015 05:31 AM
