Need some car washing advice..........
Old Jul 10, 2010 | 08:04 AM
jakesdad's Avatar
jakesdad is a jewel in the roughjakesdad is a jewel in the roughjakesdad is a jewel in the rough
There has to be a trick to washing wheels that I'm not privy to????
I'll spend an hour washing the wheels and then move the car twenty-five feet into the garage only to find out that the wheels are dirtier than ever??
It looks like I dumped a cup of brake dust and water back into the wheels...
How do I get the hidden dust and water off the wheels the first time?? Even if I don't move the car the water and dust drains down and pools at the bottom of the wheel..
Hints from Heloise please..
Old Jul 10, 2010 | 08:08 AM
buck986's Avatar
buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !
I suggest posting this and searching the detailing forum.
Old Jul 10, 2010 | 10:44 AM
stevepow's Avatar
stevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of light
I have started placing paper towels in known "drip" spots after I wash and dry the car. Tail lights and rocker panels drip water forever as do the brakes. I had the same issue yesterday though driving soon after a wash - instead of dripping down, all that brake water just blew back onto the wheels - but I had waxed them so it brushed right off with a swiffer.
Old Jul 10, 2010 | 01:50 PM
gloves's Avatar
gloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud ofgloves has much to be proud of
rinse...and when you think you have rinsed enough...rinse some more. also, what are you useing to wash them? sounds like you are not getting rid of all the brake dust on the wash portion
Old Jul 10, 2010 | 01:57 PM
NorthVan's Avatar
Brake dust will build up in the drilled holes and venting of the rotors, as Gloves said rinse and then rinse more.
Old Jul 10, 2010 | 02:57 PM
PTParks's Avatar
PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !
All the rinsing in the world is not going to stop at least some dirty water from eventually finding a way to drip on your just cleaned wheels. After cleaning and rinsing you have to get rid of the water that is just sitting in all the nooks and crannies of your brake calipers and rotors.
I use an electric leaf blower (electric, not fueled) with a shortened funnel* to blow out all the excess water from places that can't be reached with a towel. Works great on tail lights, markers, or any other seam or gap on the car. I even use it to blow the water off of the body which saves a lot of wiping and re-wiping, making it almost a touchless job to dry the car. Even the wheel wells can't escape a good blow down to get rid of excess water trapped in those areas. I usually do the tires and wheels/brake and rotors last as the blower's motor has by now warmed up enough to transfer some of the heat to the air to help further dry the car.
(* I shortened the funnel with a hacksaw and then used a heat source to soften the plastic and smoothed the cut end to prevent any possibility of a ragged edge contacting a surface. Total length of the blower and funnel is now about 18" which makes it easy to maneuver around the car.)
Old Jul 10, 2010 | 03:14 PM
jakesdad's Avatar
PT,
I'll try the blow job...... I'll use the shop vac in the blower mode and see what happens...I'll put the narrow attachment on to increase air speed..
Old Jul 10, 2010 | 03:31 PM
rosenbergendo's Avatar
rosenbergendo is infamous around these parts
The electric blowie works wonders.
Old Jul 10, 2010 | 03:45 PM
M Baker's Avatar
M Baker is infamous around these parts
Originally Posted by PTParks
Total length ...is now about 18" which makes it easy to maneuver around the car.)
Is it legal to have an 18" sawed off blower??
Old Jul 10, 2010 | 04:06 PM
gloves's Avatar
wicked idea. going to have to do this next time...like tomorrow
Old Jul 10, 2010 | 04:15 PM
KaamaCat's Avatar
KaamaCat has a spectacular aura aboutKaamaCat has a spectacular aura aboutKaamaCat has a spectacular aura about
I'm doing the same.........Have a Black & Decker electric blower and get all around the wheels. (Well the CRSpotless DIC20 helps also I have to add). One other thing I will do is drive a few times back-and-forth in the driveway while lightly applying the brakes to eliminate all water from the rotor. (So you dont end up with the tan film which will dust immediately onto the wheels first-time-out)
Old Jul 10, 2010 | 07:02 PM
Flying Cat's Avatar
Flying Cat is infamous around these partsFlying Cat is infamous around these parts
+1 electric blow job ;-)
You will get rid of 99% of water in your wheels in no time, and left over drip-drip will be negligible.
Old Jul 10, 2010 | 10:06 PM
caly's Avatar
caly is infamous around these parts
good thing i have air compressor...or i wait till i know it completely dry n go back n wipe in n out side the rim, no efford at all when i know it dry
Old Jul 10, 2010 | 11:19 PM
Jay Jones's Avatar
Jay Jones is a splendid one to beholdJay Jones is a splendid one to beholdJay Jones is a splendid one to beholdJay Jones is a splendid one to beholdJay Jones is a splendid one to beholdJay Jones is a splendid one to beholdJay Jones is a splendid one to behold
I use the Master Blaster Dryer after a wash with the CR Spotless. The Blaster is quite powerful and eliminates every drop of water from the car. Every crevice, nook and cranny is bone dry when I'm done. I never have to touch the car when drying which obviously keeps the paint looking fantastic. Here is a link to one on e-Bay. I'm sure you can also do a Google search and track down others.
http://cgi.ebay.com/ebaymotors/Autom...Q5fAccessories
Jay
Old Jul 11, 2010 | 01:40 AM
robfxlr's Avatar
robfxlr is a glorious beacon of lightrobfxlr is a glorious beacon of lightrobfxlr is a glorious beacon of lightrobfxlr is a glorious beacon of lightrobfxlr is a glorious beacon of light
Thumbs up Blow it off.........
I bought a leaf blower hears ago, after seeing a Harley Davidson detailer use it on a bike, blew off all the water in the impossible to get crannies. With a car, you get the benefit of less touching and less chance of swirls. After you use a leaf blower once, you'll never towel dry your car again.
You could go with gas operated but, I have an electric one, no maintenance, no worries...............................cheap too, a must have for your garage!!!
