997 drivers window switch not working - window stuck 1/4 from up
Old Aug 27, 2010 | 09:51 PM
Brian777's Avatar
Brian777 is infamous around these parts
Hello!
Need some help. I searched the forums about microswitches however none of the problems were the exact same as what is happening here with mine. (2005 997 C2)
the drivers side window interior switches to not operate either window currently. When using the passenger switch, it raises and lowers the passenger window.
In addition to the driver's side window rocker switches not working for either window, the drivers window does not go up and down and it is stuck in the 1/4" from the top position. It does not move at all when the door is opened or closed.
Any assistance would be much appreciated!!
Thanks!
Brian
Old Aug 28, 2010 | 08:16 PM
Brian777's Avatar
more info
Thanks so much! I have additional info. I now have discovered none of the buttons on that door work. the power mirrors do not work, the power seat does not work.
i had tried to disconnect the battery cable to try to reset. the window ended up going down another inch or more on its own but cannot be controlled by the switches. I think it tried to roll down again when opening the door. now does not move.
all the connections are connected but I will have to open it up again and triple check everything and look at everything closely.
does the control module control everything on that door?
Thanks!
Brian
Old Aug 29, 2010 | 09:45 AM
djantlive's Avatar
did u check ur fuses? its by the driver foot rest
Old Aug 30, 2010 | 11:04 AM
Brian777's Avatar
yes, checked the fuses
yes, checked all related fuses, none blown. wondering if there would be a related "relay".
Old Aug 30, 2010 | 07:11 PM
Brian777's Avatar
working now!!
working now!! not sure if the main connector was just not in all the way? I made sure it was pressed in there as well as possible and whah lah!! (main connector into the door motor/control module) thanks for all your help!
cinellipro
Dec 20, 2017 07:12 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
r_matt_6
Oct 8, 2015 06:07 PM
Sales@epl
996 Turbo Vendor Classifieds
Sep 7, 2015 02:05 PM
gulf gt
Aug 27, 2015 10:27 AM
