DIY Battery Cable Replacement??
Old Feb 22, 2011 | 06:35 PM
signature65's Avatar
signature65 is infamous around these parts
Hey, I have had my 997 since October and the battery went dead after not driving it for 2 weeks. I checked the voltage and its at 12.8V running.
I'm leaning towards the battery cable, which is a known issue! The battery was replaced right before I purchased the car. So I know that is good. I still need to check at the back of the alternator to be certian.
Has anyone replaced this cable themselves? I searched and there are price quotes from $280-$900.
Old Feb 22, 2011 | 09:57 PM
ryem3's Avatar
ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !
Good question. I think you need to pull off several panels under the car.
Old Feb 23, 2011 | 10:23 AM
sullivas's Avatar
sullivas is infamous around these parts
Check renntech.org maybe Loren (moderator) can advise you on DIY'ing the job.
You want about 13.6 - 14.5 V running I believe. I'd check the output at the alternator if you can get at it. Good luck.
Old Feb 23, 2011 | 10:35 AM
sullivas's Avatar
A lot of discussion on this topic on Rennlist:
http://forums.rennlist.com/rennforum...w-voltage.html
Old Feb 23, 2011 | 11:44 AM
///MJFDDS's Avatar
///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute
It should be 12.8V wit the car NOT running.
Old Feb 23, 2011 | 05:21 PM
I'm extremely handy with cars and have rebuilt/restored plenty of things with wheels. I'm just curious as to the complexity.
Old Dec 29, 2011 | 09:29 PM
Equinox's Avatar
Equinox is a splendid one to beholdEquinox is a splendid one to beholdEquinox is a splendid one to beholdEquinox is a splendid one to beholdEquinox is a splendid one to beholdEquinox is a splendid one to beholdEquinox is a splendid one to beholdEquinox is a splendid one to behold
sig65, you ever end up doing this? About to do it myself. I haven't looked at it, but I imagine airbox + intake mani removal will do it.
Old Jan 5, 2012 | 07:50 AM
MBENZF1's Avatar
MBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud of
I image the real work begins. I haven't found any write up's on this either, searched Rennsport as well.
Old Jan 5, 2012 | 11:27 AM
OKB's Avatar
OKB
OKB is infamous around these parts
just replace the battery and everything will be fine
DetomasoGTS74
Nov 11, 2015 09:01 AM
OldBoldPilot
Aug 24, 2015 04:00 PM
DSCOFF
Aug 23, 2015 01:22 PM
Lucid Moment
Aug 20, 2015 02:22 PM
