air intake question
Old Apr 30, 2011 | 08:28 AM
akbjr's Avatar
akbjr is infamous around these partsakbjr is infamous around these parts
air intake question
I have a 997.2, DFI. Interested in knowing if an air intake upgrade is worth the time and expense. Does it really improve the situation? Which brand is recommended. thanks.
Old Apr 30, 2011 | 04:15 PM
KonaKai's Avatar
KonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud of
This topic has been beaten to death if you search but I think it's fair to say that the gains, if any, are negligible. On the other hand, the sound improvement (particularly in the high revs), is worth the mod in my opinion. You might also consider just replacing the air filter, but be careful with oiled ones -- they can foul up your MAF sensor. Good luck.
Old Apr 30, 2011 | 07:03 PM
OKB's Avatar
OKB
OKB is infamous around these parts
the stock air box is good, just get BMC filters ( RSS - $225 )
the only thin the others offer is a longer air in tube.
Old Apr 30, 2011 | 09:26 PM
akbjr's Avatar
So does the BMC air filter need to be changed everytime the regular filter is changed or does it last longer?
Is it fairly easy to do, meaning can I do it myself?
Thanks.
Old May 1, 2011 | 07:01 AM
OKB's Avatar
OKB
its an italian filter about the same as K&N. oiled, never replaced. But its the only mfg that makes the 997.2 filter.
Take the air box out, take the screws off and open it and replace the 2 filters.
Old May 1, 2011 | 07:04 AM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Thanks.
They don't need to ever be changed actually but they do need to be cleaned from time to time. You can clean them yourself but after cleaning they need to be re-oiled. ( There is a kit that contains the cleaner, oil and and instructions available for this.) However, the process of re-oiling the filters can be tricky and if you over oil them it can cause fouling of the mass air flow sensor in the intake. Essentially, all of the cold aftermarket intake systems come with the same type of cotton filters that need to be cleaned and re-oiled from time to time. But, they all offer the improved sound so it depends on how much effert you want to put into the fitlers.
Old May 1, 2011 | 09:08 AM
akbjr's Avatar
Whats the best place to get this kit?
Old May 1, 2011 | 09:45 AM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
The 997.s air box is very efficient....no need to waste money on anything else.
Old May 1, 2011 | 10:02 AM
OKB's Avatar
OKB
RSS road sport supply right over here in the list at the right side
COBB Tuning
Jan 1, 2025 09:02 AM
Tomp
Mar 27, 2022 05:59 AM
Superaudiofreak
Sep 4, 2015 03:22 PM
ECS Tuning - VW
Aug 19, 2015 11:08 AM
