engine goes bang. 05 097s
Old Jun 22, 2011 | 01:17 PM
  #76
Taiwanese's Avatar
Taiwanese is infamous around these parts
Originally Posted by 523eric
I have not heard them refer to it as an "oil mist collector" but that should be the same part that we are referring to. I've heard "oil separator", "Air-Oil Seperator"(where AOS comes from), and "Vapor-Oil Seperator"(where VOS comes from).
Porsche's official term in their parts description in PET parts software is "oil separator", part # 996-107-026-51
Eric,
Is this, AOS, VOS, oil separator (official term), on 997 and 997.2? Where is it located in the engine compartment? Is this part common on other cars or 911 specific?
Thanks.
Old Jun 22, 2011 | 01:31 PM
  #77
PasPar2's Avatar
PasPar2 is a name known to allPasPar2 is a name known to allPasPar2 is a name known to allPasPar2 is a name known to allPasPar2 is a name known to allPasPar2 is a name known to all
I was under the impression that m97 engines didnt need the LN upgrade. isnt the engine in a 2005 997S an m97? the non S cars still had m96 engines but not the S cars.
Old Jun 22, 2011 | 02:03 PM
  #78
523eric's Avatar
523eric is infamous around these parts
Originally Posted by Taiwanese
Eric,
Thanks.
Yes, they are installed on 997 and 997.2, but are different units and part#'s on each. They started in '97 on the 986, then on the 996, 987, Cayman, 997, 997.2, 987,2... All engines have some form of crankcase ventilation/breather control.
Old Jun 22, 2011 | 02:06 PM
  #79
Taiwanese's Avatar
Eric,
Thanks for the quick reply.
So this oil separator is unique to Porsche? I have never heard of it on MB, Honda etc.
Old Jun 22, 2011 | 02:17 PM
  #80
523eric's Avatar
Well, this is where you have to determine the difference between "needs" and "wants" and "would be nice to have's"...
No car necessary "needs" an L&N kit. Even if your IMS fails, you can replace it with the stock unit.
I replaced the IMS with the L&N unit in my '98 Boxster Spec Racecar for piece of mind...did it "need" it? no, the one I removed was just fine.
Yes, the 997 IMS is a better part than the 2002-2004 models, as the early 97-01 part was better as well. Is is perfect? No. Can it still fail? yes indeed.
Would you "want" to replace an item on the car with the best part available? Sure, that's what the L&N kit is...The best part available.
It "would be nice to have" on every motor with an IMS bearing in it. The GT3/Turbo motors do not have one, the DFI motors do not have one. Any other motor it would be "nice to have" in, but not mandatory.
The good part about the '97 to most 2005 motors is that you can install the L&N kit without dissembling the motor. L&N offers upgrades for the 06-08 motors but the engine must come apart to install it.
Lastly, we have installed the kit into a couple of 2005 997S motors, not just the 3.6, as we will be attempting to do on this one. It's hit or miss, depending on the production date. You don't really know until you pull the trans to take a look at it.
Old Jun 22, 2011 | 03:02 PM
  #81
523eric's Avatar
Eric,
Porsche has their own oil separation/crankcase breathing system. But other cars have them in whatever form they decide to use. Some are very simple check valves and a couple of hoses run into the intake.
Old Jun 22, 2011 | 03:12 PM
  #82
jaspergtr's Avatar
jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !jaspergtr Is a GOD !
Wow... A BUNCH of good information here.
mkaraoglan - thank you so much for posting your entire experience. It's unfortunate for you, but I hope that others can benefit from this (it appears that already happened).
Old Jun 22, 2011 | 08:19 PM
  #83
Vancouver-BC's Avatar
Vancouver-BC is a jewel in the roughVancouver-BC is a jewel in the roughVancouver-BC is a jewel in the rough
+1. I've found this thread to be very informative on what to potentially expect and the associated costs.
Old Jun 22, 2011 | 08:38 PM
  #84
rome5982's Avatar
rome5982 is infamous around these parts
So, should the AOS be replaced as part of a preventive maintenance item?
Old Jun 22, 2011 | 10:39 PM
  #85
avh128996tt's Avatar
avh128996tt is a name known to allavh128996tt is a name known to allavh128996tt is a name known to allavh128996tt is a name known to allavh128996tt is a name known to allavh128996tt is a name known to all
Eric , how much does it cost to replace RMS+IMS Bearing(with LN Engineering Bearing)+Clutch set(pressure plate, disk and throw out bearing)+AOS +Oil change and Trans oil change.Please itemize parts and labour. pleast email me at armenhzor@hotmail.com also include your shop address and phone number. Thanx in advance.
Old Jun 24, 2011 | 08:09 PM
  #86
mkaraoglan's Avatar
mkaraoglan has a spectacular aura aboutmkaraoglan has a spectacular aura aboutmkaraoglan has a spectacular aura about
update. more bad news
It noe seems that my water pump is shot. Weird coincidence since it's unrelated to the tranny issues.
Add another $1k to my bill....
I had noticed coolant drops when I inspected the underside of my car after the AOS failure while waiting for the tow truck.
Old Jun 24, 2011 | 08:14 PM
  #87
Very sorry to hear that. Hopefully that is the last of it and you will soon be driving your car again with this mess behind you.
Old Jun 24, 2011 | 08:45 PM
  #88
AP 997S's Avatar
AP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud of
I hope your wallet doesn't go bang as well.
Old Jul 1, 2011 | 03:33 PM
  #89
mkaraoglan's Avatar
total
So I basically came in at about 4k in parts and labor for AOS, rms, l and n ims retrofit and water pump.
Add about 400 for ties and car rentals.
So $4400.
Old Jul 1, 2011 | 04:04 PM
  #90
strat10's Avatar
strat10 is infamous around these parts
Hmmm, I wonder if replacing the waterpump in a 997 is more involved than a 996? It was only 600.00 to replace my waterpump in my 996.
