Simple Audio Aux Input Installation?
Rating: Thread Rating: 2 votes, 5.00 average.
Old Jul 25, 2011 | 02:24 PM
dastro's Avatar
dastro has a spectacular aura aboutdastro has a spectacular aura about
Hello,
I want to be able to install a 3.5mm audio jack to my Navigation/Head Unit. I don't want or need to be able to control the ipod through the system (like the Denison system, etc). I just want to be able to connect via an audio cable and use the ipod to find music, etc.
Does anyone know if and how this can be done. I've seen 8 pin to 3.5mm cables but have no idea for what models or audio systems this is for. Any help and input would be appreciated!
Old Nov 1, 2011 | 04:39 PM
Djork's Avatar
Djork is infamous around these partsDjork is infamous around these parts
Bump! I would love to know this as well. Has anyone done this?
Old Nov 1, 2011 | 05:13 PM
Djork's Avatar
Old Nov 1, 2011 | 05:43 PM
antonio 997's Avatar
antonio 997 is infamous around these parts
anyone? Do you have to remove the radio to pass the wire?
Old Nov 1, 2011 | 05:59 PM
Djork's Avatar
It sounds like he used the CD changer port. Which I wouldn't mind using to use my iPod, since it has a single disc in the front anyways.
Old Nov 1, 2011 | 06:51 PM
dndodd's Avatar
dndodd is infamous around these parts
I used the Dension Gateway 500 to accomplish this.
Old Nov 2, 2011 | 08:21 AM
bspurloc's Avatar
bspurloc is infamous around these parts
Porsche iPod integration kit
I just added the Porsche iPod kit to my 2006 C2S. It requires the removal of the console but is an easy 2-3 hour project. I did the B&M Sport Shifter at the same time. This kit adds a modulator to the antenna connection then tunes the PCM to provide an AUX channel. Change songs via the iPod. It is the old iPod interface so you need a second or third generation iPod or the iPod adapter to get the iPod charging. It also has the 3.5mm audio jack you mentioned.
I got the Porsche kit from Ryan at Suncoast. http://www.suncoastparts.com/product...7S_electronics
The Scosche passPORT adapter upgrades in-car iPod integration accessories that do not support charging for your iPhone 3G, iPod nano 4th generation, and iPod touch 2nd generation. http://store.apple.com/us/product/TS696LL/A?
Old Nov 2, 2011 | 10:12 AM
Precision's Avatar
Precision is infamous around these parts
ISimple IS77 is what your looking for. http://isimplesolutions.com/product.aspx?zpid=394 It gives you the option of either an ipod cable that will charge your ipod or a headphone jack input so you can use other devices (ie.. smart phones, MP3 players) It's a glorified FM Modulator that connects through your FM antenna
Old Jun 11, 2012 | 12:15 AM
Yowzaah's Avatar
Yowzaah is infamous around these parts
Thanks Precision, I have been looking for this solution.
Old Jun 11, 2012 | 07:03 AM
kes7u's Avatar
kes7u is infamous around these parts
Originally Posted by Djork
Interested in this ebay item. If I plugged this in, where would the wire then run??
Kevin
Old Jun 11, 2012 | 07:30 AM
porscheologist's Avatar
porscheologist is infamous around these parts
Kevin
X2, where would the wire run ??
Old Jun 11, 2012 | 08:07 AM
mb230s's Avatar
mb230s is infamous around these parts
How much was the Porsche kit from Suncoast? I have the option from the factory. Since I've added the GW500 I don't need it anymore. might sell if the $ is worth the removal effort....
Old Jun 11, 2012 | 11:23 AM
griffinto's Avatar
griffinto is infamous around these parts
I burn my music to DVD. Both methods below tag music automatically and add album art. I have been using the methods for years.
Windows OS Method
RDIO or Pandora + Replay Music
http://applian.com/replay-music/
MAC OS
PandoraJAM
http://www.bitcartel.com/pandorajam/
This method takes the actual cached song and converts it.
Old Jun 11, 2012 | 07:20 PM
MBENZF1's Avatar
MBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud of
Windows OS Method
MAC OS
PandoraJAM
What does burning music to DVD's do? Can you play DVD's in the CD changer? I'm confused by this post.
I like the post with the 8pin adaptor, I did this in my BMW, it was a poor man's fix, but I didn't want to spend hundreds of dollars. I am worried about taking apart my dash, those broken clips are a B*$TH!
Old Jun 11, 2012 | 07:31 PM
Yowzaah's Avatar
I'm curious too... Where would the 8 pin adapter plug into??? Is it easy to do???
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
