steering wheel swap issues
Old Oct 7, 2011 | 06:43 PM
solrac6262's Avatar
solrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to all
the last couple of days I've been trying to swap my steering wheel triangular shape from my 09 .2 gen to a .2 newer style round airbag.. last weekend I had the car at the stealer, they told me they had some issues with the airbag, because it was not sitting properly on the SW ( tech was placing airbag incorrectly) also told me horn didnt worked ( I asked if he could do piwis on horn, I can't remember the answer but it was no) I was a little embarrassed thinking that it was my fault.. so I just had my old wheel put back on again..
during the week I did some research and some members mentioned that the column switch need it to be replaced in order to get the horn working, I placer an order on one..I ask suncoast for the part number, but my dealer had one in stock. so i bought the local one, today I took everything apart and to my surprise the steering column switch is the same part number as the one I did received..
I put the new one in just in case, tomorrow Im going to get everything programed at the dealer, I'm thinking that the first time I only need it the piwis program to get my horn working, but tomorrow I'll see if the horn doesn't work then they sold me the same switch that my car already had and need the part I've been watching some other members put in on pdk's, if horn works then I just need it piwis first time
maybe someone on the forum has done the .1 to .2 gen steering wheel but not using the pdk switch, if so and know the part number can you please tell me ..
Old Oct 10, 2011 | 12:29 AM
bottegav's Avatar
bottegav is infamous around these parts
Hope you find your answer soon!
Old Oct 10, 2011 | 01:37 AM
kitw's Avatar
kitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud of
I still think your cable is the problem. I had the same problem.
Old Oct 10, 2011 | 07:07 AM
solrac6262's Avatar
thanks guys, yes part of the problem was the cable..
second was my column switch.. order one from local dealer, I confirmed with suncoast first to get the right part# but they gave me the wrong part, so I bought a wrong swtich..
now I'm waiting for the correct part
Old Oct 10, 2011 | 02:24 PM
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
Not sure if you have a PDK car.
For a 6spd car the needed parts were:
1) New Wheel + airbag
2) New controller (to enable the changes in going from plain sport to sport+multifunc+heated)
3) New slip-ring unit to allow all of the signals from the wheel to be transmitted down to the controller.
(the slip ring is a plastic donut shaped part that has a rotating element and in internal cable system that feeds electrical signals from the input interior ring, that can rotate, to the exterior fixed ring into which the controller and car is plugged into)
Old Oct 10, 2011 | 06:16 PM
solrac6262's Avatar
thanks I have 09 .2 manual trans...
the controller I received from suncoast and my dealer is part #997 613 297 03.. same switch I have in my car now, on the triangular airbag
I haven't tried to do piwis, because I think I need the 10 control switch, for the round airbag
the switch on the 2010 is part #997 613 289 01 I think for pdk and manual..
anyone that might know, the correct part?
thankss
Old Oct 11, 2011 | 09:07 PM
solrac6262's Avatar
installed the new part and the horn is working, no piwis required, everything is working I'll test drive tomorrow..
Old Oct 12, 2011 | 12:52 PM
Ranger911's Avatar
Ranger911 is infamous around these parts
Solrac6262,
You personally replaced the steering wheel, after first removing airbag? Is the steering wheel swap a DIY-level? (I was under the impression that this was dealer-level b/c of airbag concerns.) How hard is the actual swap?
Old Oct 12, 2011 | 02:19 PM
Minok's Avatar
The work is DIY, so long as you follow the right process.
For any such work you need to disconnect the battery and discharge all electrical systems in the car (and wait) to safely pull the airbag.
The only trick in removing the wheel is knowing where the spot is that you have to puncture the current wheel body housing to trigger the release (punch a small hole), and being comfortable with what you should experience when you do so.
Beyond that, if you have to replace the slip ring, which transmits the electrical signals through a rotating mechanism, there is a 'safety pin' in the new parts that lock them in place until they are installed to make sure they don't get misaligned.
Other than that, just remember to position the old wheel top-dead-center straight, and mark the wheel and column where they engage to ensure you put the new wheel on straight again. You may, however, need an alignment afterwords, as the teeth don't always align perfectly.
Now if you are adding multi-function and heating capabilities you didn't have before, a PIWIS is needed to enable the functionality there and in the PCM, so at that point, for me, it was just easier to have the dealer do it.
Old Oct 12, 2011 | 02:54 PM
SuncoastRyan's Avatar
SuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to behold
Glad you got the issues taken car of Carlos. Let me know if I can be of any assitance. Always happy to help.
Ryan
Suncoast Parts
877-923-1700
ryan@suncoastparts.com
Old Oct 12, 2011 | 04:52 PM
solrac6262's Avatar
thanks Ryan,
Ranger, replacing the steering wheel si very easy, the hard part is if you are adding heathed or multifuncion steering wheel to a PDK or manual.. because you need a column switch.. other than that is easy, contact Suncoast, they have all the parts you might need if you decide to DIY
Old Oct 16, 2011 | 03:23 PM
Ranger911's Avatar
Thanks for answering OP/Minoc.
COBB Tuning
Jan 1, 2025 09:02 AM
STAGGERED M3
Sep 11, 2015 12:00 AM
no1joey
Sep 2, 2015 12:32 AM
pwdrhound
Aug 20, 2015 05:54 AM
MAcarbon
Aug 19, 2015 04:52 PM
