disconnect battery, radio (Bose) reset?
SubscribeHey everyone,
Happy Holiday!
I’m thinking of DIY SSK on my 06 c4s. Some people recommend disconnecting battery. If I disconnect battery, does my radio reset itself? I bought the car without any manual so I don’t have any radio (Bose) code or any other info. I’m afraid to disconnect and finds out my radio requires code to play. I search the forums but couldn’t find any answers.
Thanks!
Happy Holiday!
Thanks!
Since '03 Porsche has used the MOST fiber optic system in sound system set up thus eliminating a need for radio codes [on basic battery disconnects, etc.]. All components in the authorized fiber optic loop electronically "shake hands" with one another.
Congrats on your SSK which I know you will really like! If it's the OEM [complete assembly] you'll have no problem DIY with just some basic tools. To that extent, you don't even need to disconnect the battery doing so.
Good luck
Good luck
Quote:
Happy Holiday!
Thanks!
You may lose your preset radio stations on a battery disconnect but no radio code to worry about.Originally Posted by drive2006c4s
Hey everyone,Happy Holiday!
Thanks!
wow that's good hear that I don't even need to disconnect the battery!
yeah I can't wait to install SSK and yes it is OEM so it should be easy... I hope... I got some instruction from few people on this board so it should be all good. thank you and happy holiday!
Good luck
Originally Posted by Burg Boxster
Since '03 Porsche has used the MOST fiber optic system in sound system set up thus eliminating a need for radio codes [on basic battery disconnects, etc.]. All components in the authorized fiber optic loop electronically "shake hands" with one another.Congrats on your SSK which I know you will really like! If it's the OEM [complete assembly] you'll have no problem DIY with just some basic tools. To that extent, you don't even need to disconnect the battery doing so.
Good luck
Quote:
really??? I was going to install brand new system (replace just head unit not the whole sound system) if it requires to put code in it.Originally Posted by jhbrennan
anyways, I might not have to disconnect the battery in order to install OEM SSK after all.
thanks for your reply and happy holiday!
Hey Drive2006c4s, i'm hoping to buy the SSK in the next few days as well. which instructions did you use? i found a few docs (mostly for 996) here:Originally Posted by drive2006c4s
...yeah I can't wait to install SSK and yes it is OEM so it should be easy... I hope... I got some instruction from few people on this board so it should be all good. thank you and happy holiday!
https://www.6speedonline.com/forums/...stall-diy.html
but haven't found a dedicated SSK DIY w/pictures. perhaps one/both of us can write one up for the board?
Quote:
Documenting install for the board is always helpful or you can use the B&M SSK install directions which have pix, etc. However, since you'll have the whole assembly, you can skip steps 23-30 or so and they denote variances b/w 9x6 and 9x7 series.Originally Posted by wolfnards
Download B&M SSK Install Instructions Here
Only suggestion I have is to go for a drive and shift through all the gears before reinstalling the rear console.
Good luck
