Low tire reset trick?
Old Feb 2, 2012 | 04:49 PM
h1sp's Avatar
h1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud ofh1sp has much to be proud of
Hey all,
My low tire light came on, so I stopped and put air in my rear tires (they were at 29 lbs and now 37lbs)
Now after a day, I cannot get my low tire dash light to go off.
I have pushed and pulled the information trigger / lever…. I guess im not following the proper procedure.
Any advice?
Thanks in advance
signed.... "Sometimes im Tard did"
Old Feb 2, 2012 | 05:26 PM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
Couldn't get rid of the problem until I tried this. No more warning light.
http://forums.rennlist.com/rennforum...31-post13.html
Old Feb 3, 2012 | 10:34 AM
spiffyjiff's Avatar
spiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud of
i always post this trick but never hear back whether it works so i'll post again (and it works for me!): overinflate by a pound or 2 while the car is on. if that doesnt clear it, then try overinflating first, then resetting.
Old Feb 3, 2012 | 10:40 AM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
I assume the factory pressure specs are 33 front and 39 rear cold - at least that's what mine are. So, if you are only filling to 37 lbs you probably don't have enough pressure to reset the rears under any circumstances and perhaps the fronts as well if your tires have been driven more than a mile or two to get to a pump and they are warm. When I have to reset mine, which is typically after every track day, I generally inflate to 40/45 - ish which causes the warning lights to disappear and then bleed them back to a normal pressure after they have cooled overnight. If your tires are really warm when you add air, you might have to get the pressures close to 50 to get the lights to turn off. Hope that helps.
Old Feb 3, 2012 | 11:46 AM
DS997c2s's Avatar
DS997c2s is a splendid one to beholdDS997c2s is a splendid one to beholdDS997c2s is a splendid one to beholdDS997c2s is a splendid one to beholdDS997c2s is a splendid one to beholdDS997c2s is a splendid one to beholdDS997c2s is a splendid one to beholdDS997c2s is a splendid one to behold
Switching to alternate tire configuration in tpms setup. Starting the learn process and switching back to actual tires and redoing the process will fix issues on 997.1. You may have to drive hwy speed in a straight line. 997.2 has better sensors and faster detection times.
As a side note:
Tire pressures are really important on cars with tight suspensions and lowered like the S.
Depending on temperature outside in shade close to ground (not road temperature) adjust pressure based on chart attached. Car should not have been driven more than a mile preferably. See link on how driving for a while heats air in tires.
Here is a good read.
http://www.tirerack.com/tires/tirete....jsp?techid=73
If you are technically inclined. (Hopefully it does not have contradicting info)
http://www.arden.org/misc/pressure.html
Here is why nitrogen lasts longer when used and does not react to temperature changes much.
http://www.popularmechanics.com/cars...stions/4302788
The Porsche manual also explains this but not in detail.
Hope this helps!
Old Feb 3, 2012 | 07:31 PM
h1sp's Avatar
All great ideas.
I used Boneheads trick today and the lights are now ..... "OFF"
Thank you again.
Old Feb 3, 2012 | 08:36 PM
bonehead's Avatar
Originally Posted by h1sp
All great ideas.
Thank you again.
Great! Glad it worked. While the suggestions of overinflating the tires may work, I think it's a bit absurd to do that just to turn off an obviously erroneous light.
Plus, this one is much simpler; no touching of dirty dust caps and crouching over wheels. All can be done from the comfort of the driver's seat
horsepowerfarm
Sep 10, 2015 06:09 PM
Sales@RSW
Sep 3, 2015 09:34 AM
'02996ttx50
Aug 26, 2015 05:56 AM
Zero911
Aug 24, 2015 06:51 PM
oddjob142
Aug 24, 2015 05:49 PM
