HELP! 997 LED Tail Lights
Old Apr 10, 2015 | 02:03 PM
Tarek307's Avatar
Tarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond repute
Originally Posted by dianic
Its been a while and details slip my mind.
Here is the deal. The double filament bulb for the fog should be modded so only the second filament lights when you pull the switch. This means that the permanent "on" needs to be insulated. Hence the need for liquid tape mentioned in the instructions thread.
You can do it with regular insulating tape, note the picture of the red bulb (could be white too but not recommended as I said because it looks too bright and could be mistaken for reverse). You cover the leg to the left, with the high post of the lamp on top. Note the picture very carefully and look at your bulb and you will see what I mean.
Great simple write up- solved my issue
Old Apr 10, 2015 | 02:18 PM
jhbrennan's Avatar
Glad you got it fixed. Rottec included the modified red bulb with the tail lights that they sold...or at least provided one when requested.
Old Apr 20, 2017 | 01:19 AM
vernontwg's Avatar
vernontwg is infamous around these parts
Originally Posted by jlm7579
Dianic,
Just wanted to say thanks for all the info. I spoke with Ray and ordered the red bulbs. I bought the front LED running lights from him to. Once I install all the items, I will post a few pictures. Thanks again all!
Bringing this thread up from a while back, can you speak to the quality/durability of the Ebay lights, and what you paid for them? Thanks.
Old Apr 20, 2017 | 06:39 AM
Petza914's Avatar
Petza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond repute
I've been using 2 sets of the eBay front LEDs for years without issue. For the tails, Dectane is what I've found to be the best and I've tried almost all of them with Spyder being the absolute worst. I'd guess many of the eBay offerings are the Spyder brand and you can get them on Amazon too. It's too bad because I've had a set of Spyders on my GMC pick-up for 10 years without a single issue, but I'm guessing the bulb control module in the Porsches is more sensitive and eventually cuts power to the circuit where it detects a problem, even if there really isn't one.
COBB Tuning
Jan 1, 2025 09:02 AM
solrac6262
Sep 22, 2015 01:25 PM
Steven997TT
Aug 27, 2015 02:56 PM
