2007 997.1 Oil Pump issues?
Old May 29, 2012 | 10:42 AM
bmayer4ibi's Avatar
bmayer4ibi is infamous around these parts
I have a 2007 Carerra S with a cracked case, under warranty, to be replaced by Porsche. Are there ongoing oil pump issues that I should address with a reeplacement Porsche modified pump or aftermarket while the engine is out of the car?
Old May 29, 2012 | 01:28 PM
Alan C.'s Avatar
Alan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond repute
What caused the case to crack?
Old May 29, 2012 | 01:42 PM
IslandS62's Avatar
IslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of light
Out of the blue failure posts like this always give me the *******.
Old May 29, 2012 | 06:11 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
Have them check the contents of the oil pump carefully and open and do the same with the oil filter. You're looking for any debris in the oil which would suggest a bearing or related failure upstream. Also make sure the oil pump itself has not contaminated the oil and spread particles throughout the motor. The safe not sorry thing
Old May 29, 2012 | 07:02 PM
Alan C.'s Avatar
Gpjli
The OP is getting a replacement engine from the factory under warranty. So my guess is he won't see anything inside the engine. I get the impression that it is not an oil pump issue rather the OP is looking for any updates to the oil pump or known oil pump issues.
It would be great to see a photo of the cracked block.
Old May 29, 2012 | 07:35 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Not sure how the question is even relevant. If Porsche is replacing the engine under warranty they'll put in the oil pump they spec for that engine. Not aware of any programs they have to let you modify the engine before it's installed.
Old May 29, 2012 | 08:37 PM
Gpjli's Avatar
Originally Posted by Alan C.
Gpjli
My reading comprehension not so good you say? I read that the oil pump was broken. Thanks for the headsup. Btw: what Dadio said.
Old May 29, 2012 | 09:00 PM
MYC2SPC's Avatar
MYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really nice
Few and far between!
Old May 30, 2012 | 08:52 AM
bmayer4ibi's Avatar
The dealer says the case was cracked when it was cast. Porsche has not replied yet....New development though, they say that they're probably going the short block route, which uses existing parts rather that a remanufactured engine. Not happy about this.....
I guess I should have the entire engine checked when it is torn down? Oil pump, bearings etc. Any suggestions? I live 4 hours from the dealer, probably should hire a local mechanic to go on site to look at the torn down engine.
Old May 30, 2012 | 08:55 AM
bmayer4ibi's Avatar
Alan is right...the oil pump is not broken. I am just trying to do the right thing while my engine is apart; looking for pump issues that might occur in the future. Now that the engine is apart, perhaps I should look for more stuff....
Old May 30, 2012 | 12:01 PM
fgv1it's Avatar
fgv1it has a spectacular aura aboutfgv1it has a spectacular aura about
A "short block" usually means that the core of the engine (case, pistons, crankshaft, oil pump, heads, etc) will be supplied by Porsche as a unit, and already assembled, and all the ancillary equipment (intake system, exhaust, fuel injection components, ac compressor, alternator, etc.) will be transferred from your engine to the new block, so I don't think there will be a chance to look at all the innards of the new engine before it is installed in the car. As far as your problem is concerned (the cracked case) a short block is as good as a new engine. The concern that I would have is the quality of the work done by the mechanics at the dealership in installing all the other stuff, and any potential problems that might appear in the future as a result. Note, however, that you should get some warranty from the dealer that will cover the entire installation for some period of time.
Old May 30, 2012 | 04:04 PM
bmayer4ibi's Avatar
Thanks so much for that explanation of a short block. If that is accurate, and I'm sure it is..... this give me much relief from anxiety while I wait for an answer from the company.
I had coolant in the cylinder and am concerned that the valves and overhead assemblies were stressed upon compression. I had thought that a short block did not include these items.
Thanks again,
Bob
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
orbelo
Aug 30, 2015 12:26 PM
LiquidElephant
Aug 27, 2015 06:17 PM
The Oss
Aug 24, 2015 08:19 PM
