road noise
Old Jul 3, 2012 | 02:54 PM
hroussard's Avatar
hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !
It's the tires and as suggested, a FAT tire is much more quiet... That means an 18 inch rim with sufficient rubber on it.
Old Jul 4, 2012 | 11:29 AM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Originally Posted by kkswow12
oh, i have the 2S x-51 coupe w/o sunroof,,, LOVE THIS CAR!!!
X-51 Coupe - you shouldn't hear the tires at all. Have new ones installed -AND properly aligned.
Old Jul 4, 2012 | 03:30 PM
amge63's Avatar
amge63 has a reputation beyond reputeamge63 has a reputation beyond reputeamge63 has a reputation beyond reputeamge63 has a reputation beyond reputeamge63 has a reputation beyond reputeamge63 has a reputation beyond reputeamge63 has a reputation beyond reputeamge63 has a reputation beyond reputeamge63 has a reputation beyond reputeamge63 has a reputation beyond reputeamge63 has a reputation beyond repute
+1. Just to clarify it some more... "Fat" Tire = higher profile tires. Not fat/wider tires. Fatter/Wider tires can give you more noise too.
For the OP - I think we should not be comparing/expecting the same noise level as an A8. Apples and Oranges.
Old Aug 19, 2012 | 11:52 AM
kkswow12's Avatar
kkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nice
ok, follow-up here, when i put on 18" rims,(looking at a set of speedlines, 3 piece, totally refurbished/polished) what size tires would i use, they are 8 and 10x18, and will they fit over stock brakes? and ET's are 52 and 61
Old Aug 19, 2012 | 12:43 PM
mattgarrett's Avatar
mattgarrett is a jewel in the roughmattgarrett is a jewel in the roughmattgarrett is a jewel in the roughmattgarrett is a jewel in the rough
Mine is loud on only some highways. Most of the time it is quiet. I have new PS2s on mine. ON some interstate though it is very load. Sure if you went to really skinny tires and smaller diameter rims the noise would go down but who wants that???????? I like low profile Fat tires on mine.
Old Aug 19, 2012 | 06:45 PM
911Konigin's Avatar
911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of
Originally Posted by socalbd
I can't even hear the road over the sound of my 2008 C2S's stock exhaust. Seriously. Pirelli P-zeros stock engine, stock exhaust, only hear the loud (no complaints) engine from the cabin.
LOVE the sound of a nice engine
Old Aug 19, 2012 | 07:12 PM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
I gave up last week after my Sirius subscription expired. New tires are better than old, good roads are better than bad, etc. etc. but bottom line, there are lots of times when the road noise just overwhelms anything you're trying to listen to. So, next up, I'm going to try Pandora on my iPhone run through these:
Amazon Amazon
Best,
Old Aug 19, 2012 | 08:28 PM
keninirvine's Avatar
keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !
I've driven the three 997's I've owned (2 cabs and a Targa) over 40,000 miles and agree that the main contributors to road noise are coarse pavement (eg Interstate 5 through most of Oregon and Washington) and tires that are over half worn. On one trip from LA to Vancouver I wore foam earplugs to reduce the fatigue. It worked wonderfully. My cabs were a little noisier, but not much different. There is added rumble of noise over the top as well as through the side of the top behind the rear side windows.
Old Aug 20, 2012 | 12:46 AM
muerdeme's Avatar
muerdeme is a name known to allmuerdeme is a name known to allmuerdeme is a name known to allmuerdeme is a name known to allmuerdeme is a name known to allmuerdeme is a name known to all
My C2S is actually not that loud. I have significant road noise on some concrete surfaces where they realy put some texture on it to move water, otherwise not bad. I have bridgestone RE50's on the car (came with them from the dealer) and they are pretty well behaved.
You would have to think the car contributes somewhat to road noise (insulation level, proximity to road, etc.) but the bigger factor must be the tires...as the interface between tires and road is what is making the majority of the road noise. I would consider driving other 997 owners cars that have different tires...find one you like.
Old Aug 20, 2012 | 11:22 AM
terpsred's Avatar
terpsred has a spectacular aura aboutterpsred has a spectacular aura about
+1 on an alignment check too
As tires wear and your going to replace them anyway. Spend the cash and get an alignment. If the alignment is really off, you might be adding extra friction which translates to noise. Especially on older tires.
Old Aug 24, 2012 | 07:04 PM
Silverturbo's Avatar
Silverturbo is a name known to allSilverturbo is a name known to allSilverturbo is a name known to allSilverturbo is a name known to allSilverturbo is a name known to allSilverturbo is a name known to all
I have brand new Hancooks on my car & when I hit concrete freeway the road noise is insane but normal pavement is almost nothing. I travel the worst 30 mile stretch of freeway in Southern Oregon 1/2 fresh pavement & 1/2 concrete old road when I see that concrete coming up I have to grit my teeth to get thru it, the noise sucks.
Old Aug 24, 2012 | 10:28 PM
Sharkys's Avatar
Sharkys is infamous around these parts
I had six year old 50% tread Michellin PS2s. They felt like i was riding on frozen hockey pucks on the I5. And they were loud. I replaced all fur with RE-11s and the car quieted down a lot. The ride was much much smoother too.
BenTT
Jul 22, 2021 02:38 PM
kensilver
Sep 17, 2015 04:03 PM
Bmanny
Sep 16, 2015 08:29 AM
dailydriver
Sep 13, 2015 09:01 AM
vchris
Cayenne Turbo
Sep 11, 2015 02:52 PM
