Turn on head unit without starting car
Old Jul 3, 2012 | 09:46 AM
artyve's Avatar
artyve is infamous around these parts
Is there a way to turn on the radio without having to actually turn the engine? Sometimes I'm just sitting in the car while it's parked and want to turn on the radio.
Old Jul 3, 2012 | 09:56 AM
jhbrennan's Avatar
In my 997.1 all I have to do is insert the key - no turn or anything and it powers up the PCM...I should have said that inserting the key provides power to the PCM - I still have to push the button to get the radio to work...but I never have to turn the key.
Old Jul 3, 2012 | 12:21 PM
artyve's Avatar
I tried it just now, but it doesn't work. I put the key in tried to start the radio; nothing. Sorry but I should have said earlier, I have an aftermarket navigation head unit installed: the pioneer avic-x940bt.
Old Jul 3, 2012 | 12:41 PM
crazycarlitos's Avatar
crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !
hmmm.. i thought u don't even need the key.. just push the button on the PCM
can some1 verify pls ? i dont have my car with me and i am super curious..
OP - nor sure with the after-market unit.
Old Jul 3, 2012 | 01:16 PM
fgv1it's Avatar
fgv1it has a spectacular aura aboutfgv1it has a spectacular aura about
In my car ('06 C2S Cab) you have to turn the key to the "on" position (not the "start" position) and then you can turn on the PCM without running the engine. You will get a notice on the PCM screen though, to the effect that "operation of the PCM without the engine running possible only for a short time" or something like that, and the PCM will shut off by itself after a minute or two. I believe Porsche did this to save battery power.
Old Jul 3, 2012 | 01:25 PM
jhbrennan's Avatar
That would mean the PCM stays on when you shut the car down and take out the key - mine always shuts off when I exit and remove the key.
Old Jul 3, 2012 | 01:31 PM
artyve's Avatar
I do that too. I put it in the "on" position, or position #1 in the owner's manual and I can use all electronics including the radio. But then I get the Check Engine Light on.
Old Jul 3, 2012 | 01:49 PM
of-course mine shuts off when i take the key out.. but i thought i remembered being able to turn on the PCM within couple of minutes without the key in the hole. the PCM then shuts off automatically after couple of minutes.
i am prob mistaken.. but i will try it when i go home tonight.
Old Jul 3, 2012 | 02:55 PM
jhbrennan's Avatar
You're absolutely correct - just tried it - no key needed - I just went out and pushed the button and radio came on- key was in the house.
Old Jul 3, 2012 | 09:22 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
I don't know what sound system you have but with my PCM I hold down the power button until the unit powers on.
Old Jul 3, 2012 | 11:25 PM
drive2006c4s's Avatar
drive2006c4s is infamous around these parts
yeap, same here!
PorscheEnthusiast
Nov 13, 2015 02:23 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
vr6tee
Aug 29, 2015 03:52 AM
Rumrunner
Charity Notices/Events
Aug 20, 2015 11:07 AM
