DIY 997.2 oil/filter change
Old Jul 10, 2012 | 03:36 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
Here are the only tools needed.. No ramps, done with car on the ground and is the easiest change ever.
Here is the oil filter housing, 36MM socket. Unscrew, change rubber ring on cap, pull out old filter, replace filter and cap.
Here is the drain plug (8MM allen), and crush ring which can be reached from under rear of car (while still on ground)
Here is what you do while it s draining. Make sure you have two low profile pans to catch the oil. Replace plug and I used a new crush ring. Don t think you need to overtighten this.
Mine took 8 quarts to fill to the top line. I started with 7 quarts and it came towards the last bar. Added 1/2 qt at a time and at 8 it looked perfect ( so I know for the next time). Thanks for looking. Mark
Old Jul 10, 2012 | 04:41 PM
bbywu's Avatar
Awesome post!
Old Jul 10, 2012 | 04:46 PM
cerbomark's Avatar
Originally Posted by bbywu
Awesome post!
If you approve , maybe we can move to our DIY section? Thanks
Old Jul 10, 2012 | 05:49 PM
911cv's Avatar
911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold
Nice. It's good to see that the oil filter is not under the car anymore. Definitely makes things easier and less messy.
Old Jul 10, 2012 | 07:05 PM
daberlin's Avatar
daberlin is a splendid one to beholddaberlin is a splendid one to beholddaberlin is a splendid one to beholddaberlin is a splendid one to beholddaberlin is a splendid one to beholddaberlin is a splendid one to beholddaberlin is a splendid one to behold
Mark, how warmed up was the engine/oil when you checked to see if you had filled appropriately. I've tried to do a 'cold' check, and the car refuses to let me saying that the engine has to be warmed before a measurement can be made. Did you drive around the block and then check, let it idle in the garage? Please advise.
PS - The snow mobile is your winter daily driver, eh?
Old Jul 10, 2012 | 07:12 PM
cerbomark's Avatar
Correct, it will not measure the oil until it s at a certain temp... I put 7 qts and took a 3 mile or so ride... Oil temp was still well below 200 when it measured the level...
snowmobile is my FIX during the winter when the 911 is parked.
Old Aug 8, 2012 | 10:32 AM
LPpfs997's Avatar
LPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to beholdLPpfs997 is a splendid one to behold
997.2 Oil Change
bbywu :
Please confirm the attached image of the Oil Drain Plug is correct. My 997.2 has a 6mm allenhead not a 8mm.
Old Aug 8, 2012 | 11:16 AM
wwilliams88's Avatar
wwilliams88 is a glorious beacon of lightwwilliams88 is a glorious beacon of lightwwilliams88 is a glorious beacon of lightwwilliams88 is a glorious beacon of lightwwilliams88 is a glorious beacon of lightwwilliams88 is a glorious beacon of light
Originally Posted by LPpfs997
bbywu :
Thats not it. The oil drain plug is at the location shown by the red arrow in the photo below.
Old Aug 8, 2012 | 11:19 AM
LPpfs997's Avatar
Thanks for the image ! Have you ever bought filters from Suncoast in Florida ?
Old Aug 8, 2012 | 11:34 AM
Yes, several times. Their service is great and I highly recommend them.
Old Aug 8, 2012 | 12:31 PM
tssci's Avatar
tssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to behold
Oil temperature before draining..
When I took delivery of my '12 Turbo which shares the same new 997.2 3.8 block, the two techs that did the PDI mentioned that this new block has a series of baffles/doors in the sump that demand the oil be VERY hot when drained, and to let it drain for at least 30 minutes. You'd be amazed how much additional oil will drain out in comparison to putting the plug bag in after you see a minute drizzle of oil still coming out. Also, you want to check the level when it is equally hot - meaning at full operating oil temperature. When I followed these instructions, the Turbo took 8.14 quarts to be properly filled. The book says 'approximately 7.9 quarts if I recall correctly, and it is just that, 'approximately'. And yes, these are THE easiest oil changes of any car I've owned. Anyone would be crazy to spend what are reported to be hundreds of dollars to have it done at a dealer.
Old Aug 8, 2012 | 02:07 PM
cerbomark's Avatar
The turbo (I believe) has other areas to be drained. Do they not have seperate drains for the turbo too?
Yes I have ordered fron Suncoast, no issues.
Yes wwilliams is correct on the drain plug location.
Old Aug 8, 2012 | 02:34 PM
tssci's Avatar
997.2 turbo - just one drain plug
The 997.1 Turbos have two drain locations (engine case and oil tank), but the 997.2 have just one drain - same location as identified in the photos that have been shown.
Old Aug 29, 2012 | 05:30 PM
LPpfs997's Avatar
Great Post Mark; I did a 20k oil change, boot and undercarriage inspection while I waited. The cool oil took over 50 mins. to drain. There was a could of ounces in the filter container which I absorbed carefully. Noted during the undercarriage inspection that there are small ducts channeling air to the rear brakes. Beautiful machine !
Old Aug 29, 2012 | 06:52 PM
slick911's Avatar
slick911 has a spectacular aura aboutslick911 has a spectacular aura about
Nice write up.
