oil cooler or third radiator
Old Sep 4, 2012 | 06:41 PM
slicky rick's Avatar
slicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of light
its been an mystery to me that most in 6speed family have gone to the avenue of putting a 3rd radiator to control oil temperatures. i agree that controlling the water temperatures will affect oil temperatures. but, if the problem we would like to solve is oil temperature why not install an upgraded oil cooler?? is there no upgrade for this item. don see it at the suncoast website. are we going the 3rd rad ave since it is the only one available to control more the oil temps?
Old Sep 4, 2012 | 06:43 PM
sorry if i am not too educated on the 997 way of cooling oil. i am assuming that there is a separate oil to air intercooler to cool the oil somewhere. it the oil cooler is a water to oil intercooler connected in parallel to the cars cooling system then the 3rd rad is the only way to help.
Old Sep 4, 2012 | 07:46 PM
IslandS62's Avatar
IslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of light
I only assumed it was due to the motor placement and the difficulty of getting an aux. oil cooler into a good airflow. I would be hesitant to to run oil lines all the way up to the nose of the car, or to have something hanging below it. The 3rd radiator on the other hand is quite affordable and easily fitted.
Old Sep 4, 2012 | 10:46 PM
Alan C.'s Avatar
Alan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond repute
The oil cooler on the 997 is oil to water.
Old Sep 5, 2012 | 06:38 AM
case closed
Old Sep 5, 2012 | 01:48 PM
David9962000's Avatar
David9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond repute
The 3rd radiator on Suncoast is well priced:
http://www.suncoastparts.com/product/SKU9971TRK.html
Old Sep 5, 2012 | 03:09 PM
Yes that is true but that is for a 997.1 its funny the price for a 997.2 is almost four times as much! That is why i was wondering if someone has tried installing the .1 version on the .2 if the main radiator is the same and only the plastic pieces were different then maybe it could work! Only thing omportant really are the radiator core and mointing hardware and of course the connection hoses. If thats the same.....
Old Sep 6, 2012 | 09:06 AM
MBENZF1's Avatar
MBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud of
I've never really had a problem with cooling, can you guys provide some rational behind this? Track Days maybe?
Old Sep 6, 2012 | 12:08 PM
Alan C.'s Avatar
I think most that have gone the third radiator route have done so due to track time. I put one in my 09 CS2 M6 after seeing oil temps in the 260 range on a relatively cool day at Mid-Ohio. The oil temp dropped to 230 on a day in the mid 90s, again Mid-Ohio, after installing the third radiator.
My 11 GTS PDK has the third radiator as stock. I may be at Mid-Ohio in October. If so I'll have another data point.
On another note I installed a set of Rennline grille screens. I still can't believe Porsche hasn't provide some sort of protection for the radiators. Imagine getting a hole in one on a weekend in the middle of nowhere.
Old Sep 7, 2012 | 12:51 AM
bellwilliam's Avatar
bellwilliam is infamous around these parts
with grille screen, at best, you lost about 35% of surface. often more.
I wouldn't be surprised seeing temp go up on a track day.
Old Sep 7, 2012 | 10:57 AM
Alan C.'s Avatar
I considered that and was surprised at the results on the '09'. I had grille screens installed along with the third radiator. I should have noted that item. A friend with an '09' PDK had similar results with the same installation as mine. However, we may have had better results without the grilles.
There are some very good resources online describing air flow loss on various mesh configurations. Expanded metal, expanded metal rolled, 3 mesh 0.030" vs. 0.040, 4 mesh 0.030" vs. 0.040" etc.
Old Sep 8, 2012 | 06:12 PM
thrashek's Avatar
thrashek is a name known to allthrashek is a name known to allthrashek is a name known to allthrashek is a name known to allthrashek is a name known to allthrashek is a name known to all
I did the 3rd radiator on my previous '05 C2S... helped greatly when on the track on days hotter than 90 degrees. Good upgrade and it will keep your entire motor running cooler.
Old Sep 8, 2012 | 09:24 PM
im sure its going to produce only positive results that is why the '11 versions of the 911 have this as standard. i guess porsche run outof thing to do before the 991 that they decided to put the third rad.
Old Sep 8, 2012 | 10:33 PM
hakaida's Avatar
hakaida is a jewel in the roughhakaida is a jewel in the roughhakaida is a jewel in the roughhakaida is a jewel in the rough
I have 3 radiators. Probably because I have a GTS.
Old Sep 8, 2012 | 11:05 PM
All model 11 with pdk have 3 radiators already. Porsche made it standard for cars with pdk.
Fadi
Aug 17, 2018 05:16 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
m_motorsport
Sep 2, 2015 12:53 PM
