:: ECS Tuning :: Ziza LED Bulbs Transform Your Interior In Minutes
LED bulbs are vastly superior to stock bulbs, as they have a higher light output and are far more efficient. Installing these Ziza LED bulbs is a breeze, as you just pop out the old bulb and insert a new one, giving you incredible lighting in a matter of moments. LED illumination is a far brighter and friendlier light, creating a crisp and clean look inside your 997 instead of that dingy yellow glow that's present from your conventional filament style bulbs. Improve your interior lighting experience, open your door to a world of stunning light from Ziza.
For more information Click Here
Hi,
what's included in a kit, how many bulbs ?
Thanks.
Vincent
Thanks.
Vincent
- Front dome: 2x
- Overhead light: 1x
- Front trunk: 1x
- Engine compartment: 1x
- Door-mounted Puddle Lights 2x
- Glove Box Light 1x
- Footwell lights 2x
For a Limited time only all Ziza products are 10% off !! Start enjoying the savings today
Click Here to Select your Vehicle > By Brand > Ziza
1. Whats the LED bulb type and size in millimeters?
2. What is the lumen output for each bulb type?
3. Any of your bulbs trigger error codes and require resistors?
4. Can you upgrade the kit to even more brighter LEDs?
I'm shopping and may be interested. Questions...
1. It's a combination of 42mm festoons and T10 wedge-based bulbs
2. We don't have the lumen output
3. They will not trigger any error codes and don't require resistors of any kind
4. Not at this time
Let me know if you have anymore and I will try to answer them.
Thank you for interest and hopefully these answer your questions.
4. Not at this time
4. Not at this time
I bought these for my e46 and it was a great upgrade to brightness of OEM bulbs. The light is slighly blue-ish.
The 42mm festoons in the kit (ES2515360) are the brightest 42 MM festoons we offer. You'll need three. As for the T10 bulbs, (ES2549919) are going to be brighter then the ones offered in the kit but I can't guarantee they'll fit in all locations in the car because they are a bit bigger then the ones in the kit. We currently are waiting to get more stock of those at the moment. You would need 7 of them assuming they would fit in all the housings. The kit is going to be your best beat unless you by them individually and test / fit them.
I bought this lit for my 997 S...totally happy with the kit and the look. Brighter and more blue white than the original bulbs. They also run a lot cooler that the originals and will not (eventually) discolour the plastic lenses. I realize that the light colour might not be to everyones liking, but for me the benefits were:
...less current draw than the original incandescent bulbs (I don't drive my car often and the lower current draw means that I don't have to worry as much about constant charging of the vehicle battery)
...brighter light (I'm old and my eyes aren't what they used to be)
...longer life for the bulbs
Drawbacks (small but could be a game changer for someone that didn't know):
...my kit bulbs did not come with sufficient instructions indicating which way to install the bulbs (LED bulbs only work one way when installed).
Other than that...I'm very happy with the light, colour, operation, and the vendor!
I did the Ziza Kit a few months ago. You get a very white (touch of blue) light that is very bright. I doubt whether the responder asking for brighter LEDs really needs them. These are real bright. In fact the overhead console lights are a bit too bright (harsh); especially at night. I don't have those turn on by door opening.
