water pump failure?
Old Oct 29, 2012 | 12:23 PM
socialpro's Avatar
socialpro is a name known to allsocialpro is a name known to allsocialpro is a name known to allsocialpro is a name known to allsocialpro is a name known to allsocialpro is a name known to all
water pump failure?
Heard a strange rattling / ticking noise this am. Brought it into a mechanic they are saying its water pump at $950 replacement cost. Is that a fair value or look elsewhere? BTW this is not at the p dealer...
Car is '06 with 27K on odometer.
Old Oct 29, 2012 | 02:12 PM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
I think the part is around $300.00. Check Suncoast for pricing. They also need to do a good flush to make sure any blade/fin parts do get stuck in the engine.
Old Oct 29, 2012 | 02:57 PM
Tarek307's Avatar
Tarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond repute
Where did you take it?
tqevo's Avatar
tqevo is infamous around these parts
I had a water pump failure covered under CPO last Fall. '06 C2S with similar mileage at the time for reference. There was coolant leaking everywhere and I had to get it towed to the dealer. Have you asked for a quote from them?
Old Oct 29, 2012 | 03:25 PM
socialpro's Avatar
Becks european - getting it done there. Called a few other places was quoted higher prices, did not take it to dealer. I just thought it was extremely early for water pump failure to occur that early. I was not leaking but there was a rattle / chirping noise coming from the rear end, did not want any further surprises down the road. Sounded like a loose screw of something bouncing around in there --
Old Oct 29, 2012 | 04:15 PM
Tarek307's Avatar
I just dropped my car off there too for coil overs, intake, short shifter & aluminum pedals..best shop in Phoenix
Old Oct 29, 2012 | 04:23 PM
Sharkys's Avatar
Sharkys is infamous around these parts
Many have replace their pumps before 50K miles. Mine lasted around 50K. Indy should charge between $800 - $900 for the entire job. This is a normal maintenance item - albeit early.
Old Oct 29, 2012 | 05:57 PM
JoelPirela's Avatar
JoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond repute
mine (on the 996) needed to be replaced when the car was 115,00 miles!
Old Oct 30, 2012 | 07:42 AM
socialpro's Avatar
Yep - took it to a reputable local porsche shop and a few hours later its all good!
Old Oct 30, 2012 | 09:55 PM
Glassman's Avatar
Glassman is infamous around these parts
A recent Excellence article recommended water pump replacement as a routine preventative service in M96 engines (986 and 996), but I forget what mileage interval was recommended. I don't know about M97 engines, though. I replaced the water pump in my 2001 986S at 107K miles (after reading the article) and the impeller blades were still OK. Peace of mind.
adnanm3
Nov 22, 2023 02:43 AM
pwdrhound
Sep 13, 2016 10:44 AM
proTUNING Freaks
Oct 13, 2015 08:12 PM
carbonjim996TT
Sep 20, 2015 08:14 AM
