997.1 sound symposer?
Old Nov 4, 2012 | 12:05 PM
dwdwdwwd's Avatar
dwdwdwwd is infamous around these parts
I love the idea of having something like 991 symposer done to my 997.1.
Is there any kit/DIY out there so I can make it happen?
If possible I would love if I could toggle it or at least have it open only in sport mode.
For those that don't know what symposer is... It's the tube that brings the sound of your engine in your cabin.
Thanks!
Old Nov 4, 2012 | 12:16 PM
Gibbo205's Avatar
Gibbo205 is a jewel in the roughGibbo205 is a jewel in the roughGibbo205 is a jewel in the rough
You don't need a sound symposer to get this on a 997.1 just bypass the resonator in the air box.
Old Nov 4, 2012 | 01:06 PM
dwdwdwwd's Avatar
Is there any DIY guide out there?
Just to be clear. I don't want my car to get louder (it's loud as hell as it is). I just want to hear it better inside the cabin. I'm riding with my window half open most of the time cuz I love the sound of the engine. And trust me... Winter here in Slovenia are freezing cold.
Old Nov 4, 2012 | 02:32 PM
MYC2SPC's Avatar
MYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really nice
Run a tube from airbox to throttle body and then plug the resonator in the air box.Fabspeed has a "cold air kit" which does this but quite xpensive.
Old Nov 4, 2012 | 04:05 PM
Cas9er997's Avatar
Cas9er997 is infamous around these parts
Put the back seats down too.......I'm not kidding!
Old Nov 5, 2012 | 08:19 AM
Johnny DB's Avatar
I'll try that out tonight when I leave work.
Old Nov 6, 2012 | 06:24 AM
JoelPirela's Avatar
JoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond repute
Go to the rear deck of the car and remove the carpet portion that is right under the rear window. This is a long rectangular piece. after you remove it, you will see a 1.5" thick insulation material in the same size as the panel you just removed. Remove this insulation. Re-install your carpeted panel. You now have a 997.1 symposer!
Old Nov 6, 2012 | 06:29 AM
dwdwdwwd's Avatar
I'll try it!
I also need to try "seats down" technique
Old Nov 6, 2012 | 01:40 PM
gibbonsc4s's Avatar
gibbonsc4s has a spectacular aura aboutgibbonsc4s has a spectacular aura about
I like that carpet trick - same on 997.2?
Old Nov 6, 2012 | 02:28 PM
JoelPirela's Avatar
i assume...
Old Nov 6, 2012 | 02:57 PM
jhbrennan's Avatar
Just burn a compilation of all the 997 exhaust sound bites on the web and play the dvd while you're driving.
Old Nov 7, 2012 | 07:09 PM
Juan Cortes's Avatar
Juan Cortes is infamous around these parts
I install the fabspeed cold air intake, shuld I diconect the vacum tube from the air box?
Old Nov 7, 2012 | 07:57 PM
wc11's Avatar
wc11 has a spectacular aura aboutwc11 has a spectacular aura about
My 997.1S sounds soooooo much better after installing the Fab Speed cold air intake. 20 minutes and it looks cool too!
It bypasses the Helmholtz resonator which lowers the sound at low rpms.
Old Nov 7, 2012 | 08:07 PM
Should I disconect The vacum hose?
Old Nov 7, 2012 | 08:18 PM
wc11's Avatar
I didn't bother with the hose.
It may still be opening & closing the resonator flap but won't matter as you've bypassed it anyway.
It's there because in Europe, they don't like the noisy cars so this keeps the noise down a bit til you hit about 3.5 -4k then it opens
