Brake Pedal vibrates for split second on 2009 Porsche 997.2
Old Jan 28, 2013 | 09:08 AM
firstmovado2013's Avatar
firstmovado2013 is infamous around these partsfirstmovado2013 is infamous around these parts
Anyone experience brake petal vibrating for a split second when backing up?
Old Jan 28, 2013 | 11:16 PM
lowpue's Avatar
lowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud oflowpue has much to be proud of
no...sounds like a problem
Old Jan 28, 2013 | 11:42 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
Agree. 997.2 is pretty new so take it to the dealer.
Old Jan 29, 2013 | 06:47 AM
I've taken it to the dealer and they said it may be the brake dust thats causing the split second vibration when backing up. So non of you experienced this in the morning or backing up?
Old Jan 29, 2013 | 11:04 AM
JustinCase's Avatar
JustinCase is infamous around these parts
Does it only happen when you start in the morning? Is backing up the *first* thing you do? Does it happen again on the same trip after the first occurance?
Old Jan 29, 2013 | 11:50 AM
Usually only in the morning and its only for a split second. Maybe it has to do with ABS? As i'm backing out in reverse gear it thumps and vibrates for a split second. It doesn't always happens maybe twice a week. You can hear slight thump sound when it does happens. Its fine braking forward.
Old Jan 29, 2013 | 03:11 PM
JustinCase's Avatar
The reason I asked is that if any moisture is left on rotors and pads containing iron (like mine), they tend to rust together slightly, and you will feel a little shudder as they break apart. Living in the Seattle area where it rains more or less constantly for 8+ months at a time, the only way to avoid it in the winter is to "blow-dry" my rotors and pads every time I park with a leaf blower. This is such a nuisance I never do it, I just put up with the brief shudder. This can also happen if you wash your car without drying the brakes off.
I'm not sure how you can trigger this response in Arizona (where's the water come from?), but that's what it sounded like to me. If so, this is completely normal and covered an various other threads.
Old Jan 29, 2013 | 03:26 PM
Ok thanks alot! I never dry my rotors after washing the car so maybe i should try that next time.
2lflat4
Nov 18, 2019 05:05 PM
joseph_number1
Jul 19, 2018 05:45 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
