Low Freq. hum with AC on
Old May 31, 2013 | 05:13 PM
NYC997's Avatar
NYC997 has a spectacular aura aboutNYC997 has a spectacular aura about
Just picked up a 09 c2s and I'm having a weird issue with the AC on.
If I have the AC on and windows open there is a low freq hum inside the cabin.... If I close the window it goes away of of I open the windows and sunroof it also goes away.
Any suggestions would be great cause I can't imagine what the hell is causing this or if it's normal.
Thanks in advance
Old Jun 1, 2013 | 12:48 AM
sixgun95's Avatar
sixgun95 is infamous around these parts
Have you played with the fan speed? Maybe thats the cause. Do it get louder as the fan speed is increased?
Old Jun 1, 2013 | 07:21 AM
semicycler's Avatar
semicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond repute
Is the hum an electrical type hum? Are you hearing it in the audio system? Or more of a mechanical airflow type hum?
For a cabin airflow noise try to isolate it a little more. With the fan always on, use combinations of fan speed, recirculating air button on/off, AC on/off, ECO button on/off, only driver's window open, only passenger's window open, sunroof in various positions, windows partially open in combinations, and various driving speeds.
Start with a known condition that causes the noise and experiment by changing one thing at a time to find all the variables that make the noise go away. It's too early to guess at the cause from your description.
Old Jun 1, 2013 | 08:51 AM
NYC997's Avatar
It's happens when the AC compressor turns on and the idle falls slightly. It almost sounds like a subwoofer is on.
Fan speed makes no difference to the condition at all
Old Jun 1, 2013 | 09:06 AM
sixgun95's Avatar
Odd, I would bring it to a mechanic.
Old Jun 1, 2013 | 09:08 AM
NYC997's Avatar
Will do , I wanted to make sure it wasnt a normal thing before i swap the exhaust out and the dealership blames the exhaust on it.
Bmanny
Sep 16, 2015 08:29 AM
MrMiggy
Sep 14, 2015 02:18 PM
h00pak
Cayenne 958
Sep 11, 2015 04:37 PM
mjdVantage
Sep 5, 2015 07:22 PM
