Fuel question
Old Jun 30, 2013 | 07:13 PM
SuperPenguin's Avatar
SuperPenguin is infamous around these parts
Fuel question
A small group of friends is going on a drive this weekend, and I've been given a heads up that the quality of gas isn't so good where we are heading. I was wondering if I should be concerned, and if so what recommendations you guys have. A couple guys are taking some xylene premix as a precaution.
Old Jun 30, 2013 | 11:56 PM
sixgun95's Avatar
sixgun95 is infamous around these parts
As long as you can get gas you will be fine. These are not high compession engines so no biggy. Have fun!
Old Jul 1, 2013 | 10:48 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
unless you are gassing up in a third world country you will be fine.
Old Jul 1, 2013 | 10:53 AM
GS997S's Avatar
GS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond reputeGS997S has a reputation beyond repute
What do you consider high compression?
Old Jul 1, 2013 | 01:10 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Might help if you offered up where you were going. Folks in the states don't really have much experience with areas selling low quality gas or the need for xylene pre-mix for that matter.
Old Jul 1, 2013 | 01:41 PM
Just up in the backwoods of northern Arizona.
Old Jul 1, 2013 | 10:06 PM
sixgun95's Avatar
Bored, stroked, high compression pistons, thin head gasket, etc. Anything greater than stock compression...is high compression and often requires higher octane fuel.
Old Jul 2, 2013 | 07:53 AM
GS997S's Avatar
My GTS has a 12.5:1 compression ratio. You don't consider that high compression? I think all the 911 DFI engines are around 12.5:1, and the 911 engines do require high octane fuel. Do you not consider an engine to be high compression until it gets up to diesel compression?
Old Jul 2, 2013 | 08:35 AM
jhbrennan's Avatar
I find it hard to believe gasoline in Northern Arizona is poor quality - what are your friends basing this on? Maybe they're worried they can only get regular octane??
Old Jul 2, 2013 | 10:48 AM
sixgun95's Avatar
It is high compression compared to what? A Civic! Point is you can run on 93 octane. A modified engine often requires a booster- ours does not if stock.
You can get 93 anywhere in AZ, if your near Vegas you can even get 100 octane.
Old Jul 2, 2013 | 01:09 PM
Actually, that's not the case. Our pumps have 87, 89 and 91. 93 is not available anywhere in the metro phoenix area, though the Love's by Wild Horse Pass Motorsports Park has race fuel.
Old Jul 2, 2013 | 01:32 PM
Lyn's Avatar
Lyn
Lyn has much to be proud ofLyn has much to be proud ofLyn has much to be proud ofLyn has much to be proud ofLyn has much to be proud ofLyn has much to be proud ofLyn has much to be proud ofLyn has much to be proud ofLyn has much to be proud of
True enough, 91 octane is generally as good as it gets in Phoenix and most of Las Vegas. I spend a lot of time in both places and haven't had a fuel issue yet with my 3.6 997.1. I wouldn't worry if you are headed for the rim for the weekend as I was up there last year and 91 was generally available in Payson, Show Low and Pine Top. Have a great ride and get away from this 113 degree heat.
Old Jul 2, 2013 | 07:00 PM
jacques1960's Avatar
jacques1960 is just really nicejacques1960 is just really nicejacques1960 is just really nicejacques1960 is just really nice
Pair of panty hose to filter out the wee nasties.
Bottle of Marvel Mystery Oil just in case you miss a few...
Old Jul 2, 2013 | 09:24 PM
sixgun95's Avatar
You are correct. Error on my part.
Old Jul 3, 2013 | 07:25 AM
JB in AR's Avatar
JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !JB in AR Is a GOD !
Why not download a gas station app onto your smart phone to tell you where the good stations are?
