Stutter / lag at 1-1.5k RPM
#32
Cleaned throttle body and air filter, did the battery disconnect and reset, problem worse than before??
#33
Hey i just went through this MAF is shot cleaning it will not help. When you test your voltage on your MAF you will see your above 1.1 volts mine was 1.4 volts with key turned on position.
#34
09 C2S
had it at the dealer for several days, they tried it several days in the morning. They waited to get another 2 09 C2S to the shop. They communicated with the master tech at PNA, normal variant. If not throwing a code do not worry. Could be due to exhaust recirculation when car is very cold.
Is yours worse with colder weather?
ModBargains.com
996 Turbo Vendor Classifieds
10-01-2015 11:48 AM
panas001
09-27-2015 02:51 PM
