Outside temperature failure
Old Sep 11, 2013 | 12:26 PM
MIKCOB's Avatar
MIKCOB is infamous around these parts
Anyone have any problems with outside temperature sensor? Every time i start the car, a message of outside temperature failure shows up. Any advice would be greatly appreciated. Thanks! Btw its from MY05 997S.
Old Sep 11, 2013 | 01:15 PM
alpine-al's Avatar
alpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of lightalpine-al is a glorious beacon of light
As I recall, the sensor is in the right opening in the front bumper. Look in there for any damage that may have affected the sensor.
Old Sep 11, 2013 | 01:17 PM
IslandS62's Avatar
IslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of light
I have not had the porsche sensor fail, but had them fail from time to time on various BMWs over the years. Its a pretty cheap part and plug and play to fix. I recall seeing it in the pass. side air intake.
Old Sep 11, 2013 | 01:22 PM
MIKCOB's Avatar
I actually did check that. I don't see any loose wires and it seems like the sensor itself is intact. Anything i should check besides that?
Old Sep 11, 2013 | 01:27 PM
MIKCOB's Avatar
That's what i thought too! I don't see anybody fail there outside temperature on there porsche. I hope its just a simple fixed.
Old Sep 12, 2013 | 06:26 AM
semicycler's Avatar
semicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond repute
Check the connector on the sensor wire further upstream. Sometimes something as simple as it coming unplugged could cause this error. Happened to me after installing a 3rd center radiator on my C2S.
Old Sep 12, 2013 | 07:21 AM
spiffyjiff's Avatar
spiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud of
yep, or a fuse maybe? if nothing obvious then you could always buy a new one, swap it out. i cant imagine theyre THAT (over) pricey.
DYL 911
Oct 1, 2015 02:47 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
PelicanParts.com
911
Sep 28, 2015 04:26 PM
PelicanParts.com
Sep 25, 2015 03:17 PM
