TPMS - error light/warning question
Old Feb 23, 2014 | 12:24 PM
  #31
RaidersR1's Avatar
RaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of light
Originally Posted by Eric.ingram
I'm trying to understand this. I just changed tires on my 09' Tpms read normal psi numbers before Now it says +9 fronts. + 2 rears, It was -9 and negative 4, with flat tire light on. how can it be negative psi??? Then I saw a post about zeroing What do you do? Zero all 4 and drive it until the psi reads back out? I can't find the reading just the + /- numbers are showing Thanks
I believe the negative means it's below the recommended air pressure as set my Porsche. I would reset the Sensors back to zero and then go for a 15 minute cruise to allow the sensors to reset. If problem persist..may have to change.
zx5go
May 27, 2016 10:09 PM
AUDIRS6
11
Oct 8, 2015 12:21 PM
