Help! Rattling Noise!
Old Nov 7, 2013 | 08:29 AM
3POINT8's Avatar
3POINT8 is infamous around these parts
I have a 2006 c2s. 51k. This morning check engine light came on a few seconds later the car would rattle and sputter in 1st or 2nd gear.the only issue ive notice is leaking antifreeze under driver rear but i thought that was the crack in the tank and I've always kept it topped off. Any idea what this might be? Any mobile mechanics in the Portland Oregon area?
Old Nov 7, 2013 | 08:45 AM
spiffyjiff's Avatar
spiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud of
would it hold idle? my guess is spark/coil or the infamous MAF. first and easiest thing to do is, when symptom occurs again, unplug the MAF. then see if symptom still there. if not, MAF is to blame.
otherwise take it to a pep boys or somewhere that can read your faults/codes then report back here for more exact diagnosis.
Old Nov 7, 2013 | 04:07 PM
Scoper's Avatar
Scoper has a spectacular aura aboutScoper has a spectacular aura aboutScoper has a spectacular aura about
double check that the gas cap is on tight. Though I am not sure if it's loose it would result in rough idle...
Old Nov 7, 2013 | 04:55 PM
3POINT8's Avatar
thank you for the responses. it would hold idle. i will check the gas cap. i wonder if it's spark plug or an ignition coil???
Old Nov 8, 2013 | 06:16 PM
3POINT8's Avatar
tech read code and said it had multiple misfires. recommended new plugs, coils, fuel filter, etc. basically at 60k service at 51.5k. $1000. Am i getting ripped?
Old Nov 11, 2013 | 08:10 AM
spiffyjiff's Avatar
define "ripped". you're def in the ballpark with what shops charge (esp including a fuel pump...are you sure the $1k includes that??) but can you DIY for less? yep.
in any case, i suggest you get the actual codes just to make sure the shop is playing it straight with you and not "recommending additional work" etc.
Old Nov 11, 2013 | 09:52 AM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
As for the fuel filter, has anyone replaced it as a DIY?
Supposedly it's inside the gas tank.
rob4wellness
Oct 2, 2015 07:32 AM
Ronny-
Sep 30, 2015 07:30 PM
larryg
Sep 28, 2015 11:16 PM
