Help with front LEDs
Old Dec 2, 2013 | 11:29 AM
AZPete's Avatar
AZPete is infamous around these parts
Just installed a set of beautiful LEDs that I bought from Shane at Delreycustoms. I bought the front and the rear tailights. So far I have only installed the front lights. They went in very quickly and are a perfect fit. My only problem is that the center LED does not come on. The lower fog light works and the amber signal works correctly. What am I doing wrong? I did order the true DRL module, but I will install that at a later time. But as for now, it should still turn on with the switch. Please help. My PCM has "individual memory" feature which does have a factory DRL setting.
Old Dec 2, 2013 | 01:10 PM
Perk10's Avatar
Perk10 has a reputation beyond reputePerk10 has a reputation beyond reputePerk10 has a reputation beyond reputePerk10 has a reputation beyond reputePerk10 has a reputation beyond reputePerk10 has a reputation beyond reputePerk10 has a reputation beyond reputePerk10 has a reputation beyond reputePerk10 has a reputation beyond reputePerk10 has a reputation beyond reputePerk10 has a reputation beyond repute
This will sound simple and dumb but it is.
Take the small connector for the center LED out and turn it around and stick it back in. I made this mistake as well and thought for a second that mine were defective but in reality its just a "one way" plug!
John
Old Dec 2, 2013 | 01:14 PM
AZPete's Avatar
I did that already. Spoke to Shane and made sure to match up black with the brown wire. I need to check the fuse panel next.
Old Dec 2, 2013 | 03:14 PM
AZPete's Avatar
Anyone have any similar issues that may be able to help me figure this out.
Old Dec 2, 2013 | 03:41 PM
Perk10's Avatar
Did the lights work before the installation? (the stocks) ... It is strange that neither side works. If it were one side then I would say something is wrong but for both sides not to work... hmm. I take it you have already checked your individual PCM settings?
Old Dec 2, 2013 | 03:48 PM
AZPete's Avatar
I looked at my "individual settings" and toggled on and off the drl's. Seemed fine. May be a fuse. I am going to check the stock bulb later tonight.
Old Jan 2, 2014 | 12:07 AM
carrera997re's Avatar
carrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant future
Hey Pete did you ever fix the problem? Im having a issue with my drl. Driverside works but the pass side led strip wont light. I personly dodnt wire up the lights just curious is there a way i can just nix the led bar on the driverside? Thanks
Old Jan 2, 2014 | 07:57 AM
AZPete's Avatar
I got them replaced. But you can just disconnect the other sides strip connector.
Old Jan 2, 2014 | 08:46 AM
Sweet thanks pete IMO i think there pointless i like the bottom row led much better.
Old Jan 3, 2014 | 05:53 AM
Jack667's Avatar
Jack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant future
I had a similar problem recently with mine and I found that the cause was a connection that disconnected. I had to get the lights out and reconnect it, and now all is good. Hope that helps
Old Jan 3, 2014 | 09:40 AM
Thanks jack! Going to look into it today it was working before maybe like you said it got disconnected thanks again
Old Jan 3, 2014 | 04:00 PM
Yessss gotem!!! They work loose wire!!!
Old Jan 3, 2014 | 05:25 PM
OCT's Avatar
OCT
OCT is infamous around these parts
No more **** off I guess lol
Glad u have a perfect condition now
my left turning lights doesn't work anyway, but there is no cel on the dash, so wired.
Old Jan 3, 2014 | 06:00 PM
My prob was the connector from the drl that clicks over to the oem wire the drl little clip has a little metal wire that transfers the power was loose so i fixed them with some needle nose pliars.
cadman
Nov 13, 2025 08:57 AM
COBB Tuning
Jan 1, 2025 09:02 AM
Enemy
Nov 10, 2015 08:01 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Michael_s
Sep 11, 2015 08:03 PM
