Engine compartment fan
Old Feb 24, 2014 | 11:26 PM
808c2s's Avatar
808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !
You pick the wing that makes you happy. The engine fan mod has no favorite
Originally Posted by DOCTOR 911s
What's your opinion for this rear wing?
Is it better for the mod that you told me.
Attachment 338975
Attachment 338976
Attachment 338977
Old Feb 25, 2014 | 12:59 AM
DOCTOR 911s's Avatar
DOCTOR 911s is infamous around these parts
Originally Posted by 808c2s
Ideally, you should do both mods to maximize IAT cooling and engine coolant cooling, but try the engine fan mod first to see if you're satisfied.
Now I have this rear wing( techart type 3)
What's your opinion?
Old Feb 25, 2014 | 03:40 AM
808c2s's Avatar
See my previous post.
Old Feb 25, 2014 | 03:43 AM
Do you have any schedule in order to see my mechanic how he can do the mod?
He saw your post but he couldn't understand how to connect them
Old Feb 26, 2014 | 12:59 AM
808c2s's Avatar
Huh? I don't know what else I can say to make it anymore clear. 1999Porsche911's description is pretty straight forward. If your mechanic has access to a Porsche Repair Manual, he may be able to locate the relays. It may not be the same as 996 ones.
Old Feb 26, 2014 | 01:18 AM
Ok 808c2s
Thanks a lot....
Old Mar 1, 2014 | 12:46 PM
Anderson's Avatar
Anderson is infamous around these parts
Just find the ground pin on the relay, put a 16 gauge wire to it and connect it on a switch, the other pin from switch goes on car`s ground. Check out renntech for 997 wiring diagrams.
Old Mar 1, 2014 | 05:37 PM
nlakind
Nov 6, 2015 10:15 AM
saline
Oct 7, 2015 07:29 AM
turbotuner20v
Sep 11, 2015 12:02 PM
cinellipro
Aug 30, 2015 03:48 PM
LiquidElephant
Aug 27, 2015 06:17 PM
