Led lights
I will be using to OEM lights from a 997.2 so would like advice or know how on what I need so no error light comes on. If there is some info on this forum I can't find it. There has to be a way of installing the DRL and tail lights from a 997.2 to a 997.1. FVD sells a control module buts it like 450 there has to be a cheaper simpler solution, so I was thinking some kind or resistor just don't know what kind of voltage or wattage or what is needed, any help guys?
Before you go down the resistor route, I did notice there is a setting in Durametric for LED lights. I tried it with my aftermarket LEDs out of interest and they flashed rapidly when using the turn signals and threw error messages. I don't know if changing that setting will work for .2 LEDs, maybe someone else does?
Otherwise you will need something these:
http://store.ijdmtoy.com/LED-Turn-Si...d_resistor.htm
GSR Autosport
Aug 26, 2015 05:20 PM
