Massive Coolant Leak...HELP!
Old Apr 20, 2014 | 11:23 AM
Silverbullet911's Avatar
Silverbullet911 is infamous around these parts
Hi All, the water-temp gage was reading 190 and the oil temp was higher than normal. Parked the car and had a massive coolant leak coming from the mid bottom, not the rear. Coolant level very low. Assuming to there is a line rupture from the front radiators or bleeder valve not a water pump or reservior issues, leak is not coming from the rear. No pictictures available. HELP...
Old Apr 20, 2014 | 04:42 PM
jhbrennan's Avatar
So what kind of "help" are you asking for? Sounds like you already identified the problem - dealer visit should figure it out for you.
Old Apr 20, 2014 | 06:53 PM
carrera997re's Avatar
carrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant future
Mine burst from under the pasenger side its kinda like a elbow looking pipe and the factory clamp breaks and you get the leak.
Old Apr 20, 2014 | 08:00 PM
Robocop305's Avatar
Robocop305 is just really niceRobocop305 is just really niceRobocop305 is just really niceRobocop305 is just really nice
Remove the plastic undercarriage cover and you should be able to find the leak. Just like mentioned above I will look for that elbow.
Old Apr 20, 2014 | 11:09 PM
Thanks for the replies. Hopefully it is the elbow rather than the heater core.
Old Apr 20, 2014 | 11:52 PM
I doubt the heater core or the rad my vote says the elbow. That damn elbow failed on me twice both times complete flush of my coolent on the floor. I noticed it happend when i pushed the car really hard but then again i asked my indi if it was from the presure that the elbow or clamp gave he said no i guess its another porsche fail lol
Old Apr 21, 2014 | 12:11 AM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
How many miles when the elbow failed?
Thx
Old Apr 21, 2014 | 08:06 AM
I got 37k miles all from me. I would say failed once in the late 20k miles and the second time around @32k its such a simple fix to. First time i thought it was the rad or somthing but after pulling the plastic tray off i was happy to see just the elbow disconnected.
Old Apr 21, 2014 | 09:00 AM
3POINT8's Avatar
3POINT8 is infamous around these parts
you may also check the coolant cap. sometimes the seal gets old and a new cap fixes the problem.
Old Apr 21, 2014 | 04:55 PM
semicycler's Avatar
semicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond repute
I had a crack at the intake to the coolant overflow tank. Pretty big spill on a hot day. Consider a preemptive water pump replacement while you are in there for repairs. It's another known failure item.
Old Apr 21, 2014 | 06:11 PM
The waterfall is coming from the front half of the vehicle, no coolant loss from the rear so reservoir, cap and water pump are functioning fine, thanks for the diagnostic. This was not a slow leak, but a dump of 4 liters of coolant. Dropped the vehicle off this morning and they will not be able to repair it for three days...all this for a $5 part...
Old Apr 21, 2014 | 06:17 PM
Was it the elbow???
Old Apr 21, 2014 | 06:32 PM
Do not know if it is the elbow as they will not look at it until Thursday. Hopefully it is and all roads lead to a clamp or line failure of some sort based on the location and volume. The vehicle has 42,000 mile on the clock. Would not want this to happen on a long distance trip or on the track, motor would be cooked.
Old Apr 21, 2014 | 07:34 PM
Goodluck hope its that dam elbow!
Old Apr 21, 2014 | 09:29 PM
cab83_750's Avatar
Anyone else had this problem?
Mine has 65k and so far so good. I wonder if this should be an item worth replacing.
