05 997 rear trunk lid won't open
Old Jun 8, 2014 | 05:52 PM
lordhelemt's Avatar
lordhelemt is infamous around these parts
I tried to change the oil this weekend and the rear trunk lid is not responding to the release button.
Does anyone know if you can use the duramatic pigtail to open the rear lid or if the software can be used to reset the control?
Old Jun 8, 2014 | 08:14 PM
StormRune's Avatar
StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !
There is an emergency release wire, but it isn't always routed correctly for you to reach it easily. It is a thin cable with a loop on the end. If it is routed correctly, you should be able to find it by using a flashlight and looking up under the bumper, just under the drivers side tail light.
There is a picture showing the hole it drops down through in this thread: http://forums.rennlist.com/rennforum...ease-wire.html
Old Jun 9, 2014 | 05:06 AM
lordhelemt's Avatar
Old Jun 9, 2014 | 05:29 AM
jhbrennan's Avatar
Are you saying the electric switch isn't releasing the latch? If so, Durametric isn't going to provide any power to the switch and there is no reset. Finding the cable is the best solution. Once it's open then you can troubleshoot the switch.
Old Jun 9, 2014 | 08:39 AM
lordhelemt's Avatar
Exactly, the switch want release the latch.
Strange the Durametric can pop the hood bu not the rear lid. Ill trouble shoot later this week and report back
Old Jun 9, 2014 | 08:51 AM
jhbrennan's Avatar
Durametric cannot pop the hood.
Old Jun 9, 2014 | 09:27 AM
lordhelemt's Avatar
I was able to pop the hood using the Durametric yesterday. The control is in the front section. I wasn't able to find the control for the rear lid in the rear section.
Old Jun 9, 2014 | 11:27 AM
jhbrennan's Avatar
I learn something new every day. What do you mean by front section?
Old Jun 9, 2014 | 06:52 PM
lordhelemt's Avatar
To pop the hood go to "front" on the menu to the left. under activations use the command "servo motor front lid release" and it should pop the hood.
Back to my problem. Does anyone know if the rear control unit also controls the rear lid?
Old Jun 9, 2014 | 08:02 PM
lordhelemt's Avatar
Fixed.
Little embarrassed but it was a 15amp fuse.
Old Jun 9, 2014 | 08:04 PM
Mlv_250's Avatar
Mlv_250 is infamous around these parts
Once you figure out how to open the lid, you might want to extend the cable into the rear wheel well. And ditto for the frunk!
ID:	384874   Click image for larger version
COBB Tuning
Jan 1, 2025 09:02 AM
werkzrs
Apr 23, 2020 12:03 PM
2lflat4
Nov 18, 2019 05:05 PM
Mackchacha
Jul 9, 2019 11:03 AM
gulf gt
Aug 27, 2015 10:27 AM
