Durametric Code Help
Old Dec 15, 2014 | 09:40 AM
3POINT8's Avatar
3POINT8 is infamous around these parts
my engine light keeps popping on. I check it with my durametric tool and the DME code is "Exhaust Flap Failure Final Stage" anyone know what that means? Car runs fine. I clear the code and go a few hundred miles then it pops back on. thanks!
Old Dec 16, 2014 | 12:22 PM
3POINT8's Avatar
please help!
Old Dec 16, 2014 | 01:05 PM
jhbrennan's Avatar
Originally Posted by 3POINT8
please help!
What is the actual DTC number/code?
Old Dec 17, 2014 | 11:33 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
Old Dec 19, 2014 | 10:41 AM
3POINT8's Avatar
IT is P 1043
Old Dec 19, 2014 | 12:00 PM
StormRune's Avatar
StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !
If it is a standard OBD-II code, it means "Injector 3, supply voltage - short circuit". However, searching for that code online looks like there may be other possibilities. I don't see how the exhaust flap one makes any sense on your car.
I would you call or visit your local Porsche service department and ask them to verify the meaning of that code for your car.
Old Dec 19, 2014 | 02:54 PM
3POINT8's Avatar
thanks for the help, i'll try googling it as well as see what I can find
Old Dec 20, 2014 | 09:47 AM
Macster's Avatar
IT is P 1043
Error codes that start with a '1' are manufacturer specific. You need access to the Porsche error code reference to know what that code specifically refers to.
You might have some luck googling the error code with something like "porsche 997 P1043"
I did and this is what I found:
P1043 Electric air cleaner flap
Possible fault causes
- Short circuit to B+/ground or open circuit in the control line
- Open circuit of power supply to air cleaner flap solenoid valve
- Air cleaner flap solenoid valve faulty
- DME control module faulty
Old Dec 28, 2014 | 06:59 AM
semicycler's Avatar
semicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond repute
Was browsing through some PDF's downloaded in the past. One of them is a 2006 997 DME Diagnosis document listing DME OBD-II codes. Directly from that document:
P1043
Diagnostic conditions
  • Power supply voltage > 7 V
  • Engine start-up and subsequent engine running > 10 s
  • Short circuit to B+/ground or open circuit in the control line
  • Open circuit of power supply to air cleaner flap solenoid valve
  • Air cleaner flap solenoid valve faulty
  • DME control module faulty
The interesting part is P1041, P1042 and P1043 all have identical text in the document.
Old Dec 28, 2014 | 11:59 AM
PatrickBateman's Avatar
PatrickBateman is infamous around these parts
OP... don't have the code erased. keep it saved in your ecm, so your mechanic can diagnose it properly.
Keep us posted. good luck.
Old Dec 29, 2014 | 11:01 AM
3POINT8's Avatar
ok thanks so much. I'm curious as to what this may be
BLKMGK
May 31, 2016 04:32 AM
jdbaker
Sep 19, 2015 10:34 AM
arhim22
Sep 7, 2015 08:49 PM
