LED DRL Warning Light Issue
Old Jul 20, 2015 | 08:25 PM
kotykb's Avatar
kotykb is infamous around these parts
I installed a set of LED DRL's from eBay's seller Fishcake321 which is a reputable seller. I installed the lights per the installation guides from this forum and I'm stumped. From the troubleshooting that I've done, the wrap around DRL light bar is throwing the Check Front Side Left and Right Light warning on my dash.
I pulled the lights out and plugged the OEM bulb into the socket and boom the warning is gone. The seller said there isn't a need to add a resistor to the light.
Has this happened to somebody else?
Old Jul 20, 2015 | 10:22 PM
RaidersR1's Avatar
RaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of light
happened to me too. The error only comes on when I have the headlights on. With my headlights off...no error.
Old Jul 20, 2015 | 10:24 PM
kotykb's Avatar
Old Jul 21, 2015 | 08:06 AM
yvesvidal's Avatar
yvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of light
I am not an expert, but there are some modules sold on E-Bay or other places that will usually solve the lack of current draw by LED based light equipments.
I have used some of these with success on my BMW 540i, when I installed HID lights in the front.
These modules are not using Resistors in in parallel with the lights, as this way of doing it would be equivalent to having a Bulb plus the LED consumption when the lights are on.
I think they use a capacitor which presents itself as short circuit, when the pulse sent by the control unit (to verify the presence of the bulb) reaches the Light Error Avoidance module. When the light is ON, the capacitor is fully charged and does not react to the constant flow of current coming to it.
Yves
Old Jul 21, 2015 | 02:51 PM
kotykb's Avatar
Yves
Do you mind attaching a link to this type of in-line capacitor?
Old Jul 22, 2015 | 01:14 PM
yvesvidal's Avatar
This is what I used for the HID Halo lights on my BMW 540i:
http://www.ebay.com/itm/2x-Warning-E...item20ee25359a
You may have to check the connectors or adapt them to your needs.
Yves
Old Jul 22, 2015 | 09:40 PM
kotykb's Avatar
FYI The resistors from Amazon work and eliminate the light error. I used electrical tape on the connections to ensure they don't loosen over time. The resistors do get pretty hot but they're dangling in an open cavity in the front bumper, what's the risk?
Old Jul 23, 2015 | 05:53 PM
teamvwr's Avatar
teamvwr is infamous around these parts
kotykb, I also purschased a set from fishcake123 for my 997.1 and have the same problems with the warning light issues. What resistors did u buy from Amazon to fix the warning light issues? It would be much appreciated.
Old Jul 23, 2015 | 08:54 PM
kotykb's Avatar
The link is above, read my posts.
cadman
Nov 13, 2025 08:57 AM
COBB Tuning
Jan 1, 2025 09:02 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
pwdrhound
Aug 23, 2015 07:36 PM
