Please take a few secs to answer question re: your water pump
Old Aug 5, 2015 | 03:26 PM
GBG's Avatar
GBG
GBG is a jewel in the roughGBG is a jewel in the roughGBG is a jewel in the rough
It would be interesting to see the anecdotal data on water pump deaths to help determine the mileage point where replacement as a preventative measure is the way to go. I'm at 60k miles with no sign of trouble, but I plan to replace it as preventative measure next week unless these numbers strongly suggest otherwise.
Please take a few secs and tell me how many miles were on your car when your water pump died OR tell me how many miles you've now got on your car with the original water pump still pumpin'. Thanks!
Old Aug 5, 2015 | 03:37 PM
Rotor's Avatar
Rotor is infamous around these parts
28,670 miles water pump replaced under warranty.
Old Aug 5, 2015 | 03:43 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
Don t you think 997.1 and 997.2 have different pumps?
The info won t help you if it s for a different motor... maybe you need to be more specific.
Old Aug 5, 2015 | 04:29 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
Aaaargh! This has been beaten to death and beyond. Do a search and then do whatever you want. You'll not find the answer you are looking for.
Old Aug 5, 2015 | 05:36 PM
nwGTS's Avatar
nwGTS has a reputation beyond reputenwGTS has a reputation beyond reputenwGTS has a reputation beyond reputenwGTS has a reputation beyond reputenwGTS has a reputation beyond reputenwGTS has a reputation beyond reputenwGTS has a reputation beyond reputenwGTS has a reputation beyond reputenwGTS has a reputation beyond reputenwGTS has a reputation beyond reputenwGTS has a reputation beyond repute
PO replaced water pump at 19831 miles on 9/19/14 while still on lease. I was told it was preventative as an incentive for him to buy it when it came off lease but he went with a new 991. Currently at 24,800 miles.
Old Aug 5, 2015 | 06:19 PM
PTParks's Avatar
PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !
~24,600 miles on original water pump. No issues, but added an extended warranty when the factory warranty expired for peace of mind.
Old Aug 5, 2015 | 07:33 PM
barncobob's Avatar
barncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the rough
06, 31K, no problems so far but check for warning signs all the time..
funny , my girlfriends Honda has 143K, no problems, but I do change Honda coolant every 50K, no oil leaks, seepage anywhere, original auto trans, car is amazingly reliable.
Old Aug 5, 2015 | 08:35 PM
MYC2SPC's Avatar
MYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really nice
2006 C2S, 40,500k just had it replaced under Fidelity Warranty 3 weeks ago!
Old Aug 5, 2015 | 08:46 PM
Robocop305's Avatar
Robocop305 is just really niceRobocop305 is just really niceRobocop305 is just really niceRobocop305 is just really nice
2009 C2S, 38,000 miles on original pump. No issues.
Old Aug 5, 2015 | 11:12 PM
SoCal C2S's Avatar
SoCal C2S is infamous around these parts
Just replaced the pump 3 weeks ago as preventative. Indy said it was the best looking original pump he's replaced on the 997 series. Did the thermo at the same time.
06 C2S, 52750 miles.
Old Aug 6, 2015 | 09:51 AM
PTParks's Avatar
So spoke the new member with 4 posts.
Old Aug 6, 2015 | 10:16 AM
thethor's Avatar
thethor is infamous around these parts
I just replaced at 23,000 miles, along with thermostat. Bearings failed, and it started leaking. It's an 07 C4S cab.
Old Aug 6, 2015 | 10:57 AM
lacrosse's Avatar
lacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud oflacrosse has much to be proud of
Mine failed at 75,000 miles (if I remember correctly). Replaced under CPO warranty.
Old Aug 6, 2015 | 11:04 AM
yvesvidal's Avatar
yvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of light
Mine is still running fine at 67K. 2006 C4S gently used most of the times....
Yves
Old Aug 6, 2015 | 03:35 PM
devil boy's Avatar
devil boy is infamous around these parts
Replaced at 80K as preventative maintenance.
