ECS Magnetic oil drain plug stripped! Plz help
Old Nov 4, 2015 | 11:10 AM
Vladm's Avatar
Vladm has a spectacular aura aboutVladm has a spectacular aura aboutVladm has a spectacular aura about
Originally Posted by StormRune
Vladm, It's not clear to me if you are saying the allen head stripped like MillerTime shows or whether the threads that mesh with the oil pan stripped. It may help to clarify.
Yes it stripped and looked just like his
Old Nov 4, 2015 | 12:56 PM
Buddhamonk's Avatar
Buddhamonk has a spectacular aura aboutBuddhamonk has a spectacular aura aboutBuddhamonk has a spectacular aura about
Originally Posted by Vladm
The F****r is out!
Tried Easyout- no luck.
used dremel to make a deeper notch and fabricated a wide "screwdriver" by grinding the hole bit. Locked vice grip and turned it as a lever. Bingo!
Stay the hell away from these plugs!!!!
I bet the plug would be fine if people used only 25-30 ft/lbs of torque on it
Old Nov 4, 2015 | 03:28 PM
jhbrennan's Avatar
The F****r is out!
Congratulations!! Before it stripped, was it a hex fitting (8mm?) or was it a Torx fitting?
Old Nov 4, 2015 | 03:47 PM
slicky rick's Avatar
slicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of light
Confusion coming from stripped and rounded. Stripped threads rounded hole
Old Nov 4, 2015 | 05:20 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
Thought it was me . The OP learned a new skill today. Great site!!
Old Nov 4, 2015 | 05:23 PM
cerbomark's Avatar
Someone told me although a 8mm works it s really a torx configuration. I ve always used a 8mm even after being advise against for this very reason... ???
Old Nov 4, 2015 | 05:42 PM
jhbrennan's Avatar
I was told just the opposite - it's 8mm hex and not torx and that using torx may cause the rounding. Maybe ECS can confirm.
Old Nov 4, 2015 | 09:42 PM
djantlive's Avatar
why do you guys use a different plug? for the magnetic to catch some possible shavings as a way to identify IMS failure?
Old Nov 4, 2015 | 09:56 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
Torx or hex? Oh my!
Old Nov 5, 2015 | 03:52 AM
b2sc's Avatar
b2sc is infamous around these parts
...and you'd lose that bet. The aluminum used for the plug is very soft and the hex slot is not deep enough to withstand the forces required to loosen and tighten the bolt plug to spec.
Old Nov 5, 2015 | 05:59 AM
semicycler's Avatar
semicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond repute
Main Oil Drain Plug, M18x1.5mm thread, 8mm hex bit
OEM Torque: 37 lb-ft
Magnetic Aftermarket Torque: 19 lb-ft
Old Nov 5, 2015 | 06:08 AM
jchapura's Avatar
jchapura has a spectacular aura aboutjchapura has a spectacular aura about
Yes. Trying to trap as much magnetic metal as possible (from any source but there's not as many sources as say a small block Chevy with a cast iron block). Magnetic drain plugs (and adjuncts, like in some automatic transmission pans) have been around a long time.
A magnetic metal sensing sensor is the basis for an IMSB add-on warning system (I think named Guardian?).
Old Nov 5, 2015 | 06:11 AM
Vladm's Avatar
Thx! 8 mm.
Old Nov 5, 2015 | 06:16 AM
Vladm's Avatar
Correct.
The hole got rounded and the 8mm hex could not get the plug out. The threads were unaffected.
Sorry for the confusion.
Similar effect and a major PIA.
Old Nov 5, 2015 | 10:13 AM
Gpjli's Avatar
I think you need to consider the possibility that not all folks recognize the difference between Torx and Hex. Using the wrong tool is the easiest way to strip any piece. Ask me how I know.
