Jersey Shore Porsche Indy- leak in my car
Old Jul 5, 2016 | 05:42 AM
Raym50's Avatar
Raym50 is infamous around these parts
I am in a 997 cab. I posted a prior thread where one of my control modules got ruined due to water leaking under my driver seat. The mechanic couldn't fix the leak. I went to a body shop that had no idea where the drains are or hot or trouble shoot the issue.
Can anyone recommend someone around the jersey shore, ocean township, that can handle this issue for me?
Old Jul 6, 2016 | 02:19 PM
FlaHeel's Avatar
Did you check the door drains like I suggested on your previous thread?
Old Jul 6, 2016 | 03:05 PM
Raym50's Avatar
Hi FlaHeel - Thank you. I am not too good with my hands and did not want to screw up the car, so I ended up hiring "the Water Doctor". My body shop recommended that I call him up. He did check the door drains, based on me telling him about your recommendation (He otherwise had no clue about the 997 - he couldnt even open/close the windows). But he did open the side panel and found a pool of water when he tested it with a hose sitting in the tray in the door. He basically had to clear the drain which was completely clogged. Cost me $200, which I am sure i couldve done myself if i had a pair to explore the car.
I would have liked to go to someone that knows the P cars in and out, but this is what I got.
Old Jul 6, 2016 | 06:31 PM
akunob's Avatar
akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !
I highly recommend Bodymotion Racing in Ocean Township on Cindy Lane. Ask for Ace, he'll take care of you. Porsche guys to the core!
Old Jul 7, 2016 | 04:35 PM
tommyv's Avatar
tommyv has much to be proud oftommyv has much to be proud oftommyv has much to be proud oftommyv has much to be proud oftommyv has much to be proud oftommyv has much to be proud oftommyv has much to be proud oftommyv has much to be proud oftommyv has much to be proud of
Why not take it to a dealer? That's the first thing I would do.
Tom
Old Jul 7, 2016 | 06:32 PM
FlaHeel's Avatar
Glad it's fixed. There are some really good DIY articles on this forum and if you use the search function normally something will show up. Good luck.
Old Jul 8, 2016 | 11:17 AM
Macster's Avatar
Not sure it is fixed. To the OP: Water in the door suggests the door membrane is leaking. This either has to be reglued or if the membrane is tore/ripped/split, replaced and this too involves gluing it in place.
Old Jul 8, 2016 | 01:01 PM
Quadcammer's Avatar
Quadcammer is infamous around these parts
Bodymotion is good. Bit proud of their work ($$$) but they seem to do a decent job.
txoso
Sep 20, 2016 01:38 PM
turbo_secret
Bentley
May 29, 2016 02:29 AM
Hi-Arc
Apr 26, 2016 02:37 PM
ECS Tuning - VW
Apr 7, 2016 10:59 AM
