Help Needed for Headlamp Adjustment Fault
Old Jul 16, 2020 | 07:51 AM
ttreat1's Avatar
ttreat1 is infamous around these parts
I have a "headlamp adjustment fault" on startup. With my Foxwell NT530 and am able to see through the live data that the left motor position does not changing as I drive. I also see a fault code on the module (8040) which noted "No Signal/Communication- DTC-LN Bus stepper motor, HBA left". The headlamps move both vertically and horizontally when I do the light switch/key position calibration test. I would assume this means that there is either a wiring connection or module issue not the stepper motor.
Has anyone seen this or have any thoughts on how I can find the source of my problem?
Yves
Apr 11, 2020 04:06 PM
Scrotius
Dec 14, 2019 09:58 PM
harihoudini
Bentley
Dec 10, 2019 10:11 PM
jetengine
Cayenne 955/957
Oct 15, 2019 04:19 PM
e36uc
Jan 30, 2019 07:47 AM
