2006 997 3.6 check engine o2 sensor values
Old Dec 27, 2020 | 03:57 PM
Simon Kowalczyk's Avatar
Simon Kowalczyk is infamous around these parts
Hi guys long time member new account.
120k miles. 6 speed
Can’t seem to get rid off my cel, replaced mass airflow replaced b1s1 all OEM Bosch
on cold start the car will start normal but then misfire after warming up for 1-2min, I get misffire codes only on one bank 1-3 Cylinders
Thinking both banks sensor 2s post are done I have x pipe cat delete with 90degree spacers
can someone let me know if these values from 02 sensors reading are way off on both banks
Old Dec 27, 2020 | 05:03 PM
forbes210's Avatar
forbes210 is infamous around these parts
What are the codes you're getting?
Old Dec 28, 2020 | 06:37 AM
Petza914's Avatar
Petza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond repute
Read the Bank 1 and Bank 2 camshaft deviation numbers. My car had exactly this same behavior when the camshaft position sensor failed. When the car is first started it runs in open loop so ignores those sensors which is why it runs fine for 1-2 minutes. Then it switches to closed loop and when it doesn't get the data from that sensor it throws the code and starts stumbling. I bet if you pull those values, the bank 1 sensor that's throwing the code shows all zeros.
Old Dec 28, 2020 | 09:29 AM
Originally I replaced a MASS AIR FLOW for flat spots upon acceleration 4-5K rpms and that resolved it, then I had o2 sensor bank 1 sensor 1 code for system to rich that resolved it now Im still getting the CEL
P2196
P2198
then missfire codes only bank 1 cyl 1-3
P0300 Mult Misfire
P0301 Cyl 1
P0302 Cyl 2
P0303 Cyl 3
Old Jan 27, 2021 | 05:22 PM
JesseBertone's Avatar
JesseBertone is infamous around these parts
What's the age of your coil packs? Have you replaced them? I have 122k on my 2006 C2s and i started to get hot misfires. This was at about 105k maybe. I replaced all plugs and coil packs and it hasen't misfired since.
00dehj
Jan 15, 2021 08:03 AM
turbo_secret
Bentley
Apr 11, 2017 06:29 PM
Thklinge
Sep 13, 2012 08:14 PM
qvt408
Jan 21, 2011 06:40 AM
Harmony Jim
May 17, 2010 05:39 PM
