Oil Questions
Old May 1, 2007 | 10:40 PM
ApexHunter's Avatar
ApexHunter is infamous around these parts
Oil Questions
So,
My 997s now has 900 miles on it. When cold, it seems like the oil measures half way down from it's "full" mark. When hot, the measurement is at the full mark. Dealers says 0-w40 is the recommended oil. (mobil 1 of course).
Manual says to check during re-fuleing, not if it's cold or hot?
What to do?
Queston 1. Should I add a bit?
Question 2. Should I go with the 0-w40 for Southern California climate?
Thanks!
>>>Apex.
p.s. 2k miles can't come fast enough!
Old May 1, 2007 | 10:49 PM
Byronmaui's Avatar
Byronmaui is a splendid one to beholdByronmaui is a splendid one to beholdByronmaui is a splendid one to beholdByronmaui is a splendid one to beholdByronmaui is a splendid one to beholdByronmaui is a splendid one to beholdByronmaui is a splendid one to beholdByronmaui is a splendid one to behold
Sounds normal. I would not add any oil to the car because overfilling is not good for the engine. Amazing there is no dipstick. Personally I am a dipstick kind of guy. Oh well.
Aloha
Byron
Old May 2, 2007 | 04:42 AM
larrytrk's Avatar
larrytrk is infamous around these parts
Check cold unless you have 20 minutes to wait! I keep 1 bar down, that way you never overfill and you don't hurt the engine.
Old May 2, 2007 | 04:58 AM
mishref's Avatar
mishref is infamous around these parts
I am using 0-W40 in Kuwaiti (40 - 140f) weather ... works great.
Old May 2, 2007 | 06:40 AM
porschenut911's Avatar
porschenut911 is infamous around these parts
I usually keep it at 4-5 bars. Use 0-W40, oil is not just an engine lubricant, it's a coolant and hydraulic fluid for your engine too!
Old May 2, 2007 | 07:41 AM
JCS's Avatar
JCS
JCS is infamous around these parts
Which model do you have?
My 997 S oil level gauge has only 3 bars and the engine is cooled by some antifreeze solution.
I'm also pretty sure that engine oil is not used as a hydraulic fluid in my car .
Old May 2, 2007 | 11:37 AM
I have a 996 with 8 bars on the dash. Yes, oil acts as a coolant too and a hydaulic fluid for the variocam! As for that antifreeze stuff, I got some of it too!
Old May 2, 2007 | 11:58 AM
JCS's Avatar
JCS
Thanks.
I must have gotten confused about the oil level bars.
I thought the guy who asked the question has a 997 , as I do .And we only have 3 bars . In which case, you telling him to keep it between 4 and 5 won't be of much help .
Old May 2, 2007 | 01:29 PM
TheJudge's Avatar
Turn PSM Off
TheJudge is infamous around these parts
Originally Posted by JCS
Thanks.
I have more than three bars on my 997.
Old May 2, 2007 | 10:45 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
Read the manual as to when and how to check the oil and how to interpret the bar gauge. It can most easily be done in the am (cold) on a level surface.
Old May 3, 2007 | 03:31 AM
GrettW's Avatar
GrettW is infamous around these parts
I recommend amsoil 5w-40 european spec for your 997, do some research it is far superior to mobil1
Jul 29, 2019 11:13 AM
away
Sep 4, 2015 12:30 PM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
