19 inch tires and pressure question
so i've read articles and posts about 19 inch tire ride stiffness. what are most people running for psi on their 997s 19 inch tires?
anyone switch to 18s?
Try some different pressures until you find something you like that is within range of what Porshe suggests. My door says something like 33/39 (cold), so that's what I leave it at off track. The lower you go, the softer the ride...
Too low (ie: 39 hot) on the track and they are going to roll over too much. I experimented with hot pressures at 5 different track days and found 42 hot rear, 40 hot front to work pretty good. The lack of camber is what really limits these cars...
Car is stored winter months - but when it does get colder/warmer I just adjust to get 33/39.
Mike
Starting to put some heat in them... My last DE I had 42 hot rear left driver's side that went down to 31 cold (that was an 11 PSI drop from hot). That was the most - left front was 10 PSI different and I think the other side was 8 PSI front and back. I was surprised the left rear went up the most, thought it would be left front as it was in my M3. Difference is weight and power.
I have the Pirellis. The dealer set them right to what the sticker on the door says for normal weight in the car. After a month or so I added about 2 pounds to each. I was worried it would be too stiff, but I like it even better
