C6 Oil/Coolant Issues
Old Sep 30, 2008 | 06:54 PM
chpkorean's Avatar
chpkorean has a spectacular aura aboutchpkorean has a spectacular aura aboutchpkorean has a spectacular aura about
Hi guys,
I have a 2005 C6 vette, that I am having some issues with.
Today out of nowhere when I left her idoling, the oil temperature spiked to 215-217, and the coolant went to 210-212ish. The only other time this has happened was when my serpentine belt snapped off causing everything to obviously go crazy. I checked the belt it was tight and straight, checked coolant levels looked fine, and no leaks.
Anyone else have any ideas?
Old Oct 1, 2008 | 12:25 AM
JFrazier's Avatar
JFrazier is infamous around these parts
Were you in traffic? Those numbers are pretty normal for a stock 'Vette. These cars like to have a lot of air moving and they'll run warm when sitting.
Just wait until you start racing and your oil temps hit 300F. Then you might have to slow it down a bit.
Old Oct 1, 2008 | 08:49 AM
greekc6's Avatar
thats normal especially if its hot. ive seen mine hit 219-220.
Old Oct 4, 2008 | 10:30 AM
newsie23's Avatar
newsie23 is infamous around these parts
Coolant
I have used Tufoil to reduce friction. In extreme cold, I have blocked off the rad! because the heater didn't 'work'. If used, I would assume the EPA Warmup cycle would fail
adnanm3
Nov 22, 2023 02:43 AM
PV=nRT.
Sep 9, 2022 06:06 PM
Paintballzen
Oct 10, 2020 12:22 PM
georgemaser
Oct 17, 2015 05:59 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
