AM V8 Driving
Old Nov 17, 2009 | 12:44 PM
shvt's Avatar
shvt is infamous around these parts
AM V8 Driving
I'll start off apologizing if this question has been asked before. I tried searching with no results. My AM is an 09 and I picked it up new last week. When driving your AMV8, do you notice a knocking on your steering wheel, like a force feedback on PS3 controllers? I asked the dealership and the sales person said that it is normal. He mentioned that Top Gear mentioned this with their review.
Old Nov 17, 2009 | 03:22 PM
Michael 996TT's Avatar
Michael 996TT is infamous around these parts
Don't have that in my '07 ...
Old Nov 17, 2009 | 05:33 PM
Jay_Davis's Avatar
Jay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud of
The only "knock" I've had on the steering wheel is when going over a pretty serious bump at highway speeds. Outside of that, no such thing. This is on an 09.
Old Nov 17, 2009 | 06:29 PM
AstonAficionado's Avatar
Awaiting Email Confirmation
AstonAficionado is infamous around these parts
I haven't noticed this myself. Also, I'm pretty sure Top Gear hasn't mentioned this in regard to the Vantage (I've watched the Vantage eps many times). Maybe they said something similar in regard to the other AMs.
Old Nov 17, 2009 | 09:23 PM
shvt's Avatar
Yes, this is what I'm referring to. Yeah, it is like a knocking sound from the steering wheel when hitting some bumps. I guess this is normal then. I'm surprised nobody talked about this. I totally thought it was abnormal.
Old Nov 17, 2009 | 10:01 PM
gekko's Avatar
gekko is infamous around these partsgekko is infamous around these parts
http://www.amoc.org/forum/index.php?topic=794.msg9907
There where two separate issues on this:
1) Airbag rattling inside the steering wheel (case by case, I've read some where changed by dealers)
2) Rattle in the steering column on very rough roads. (no solution that I know of - I get the same in my car over bad potholes)
Old Nov 17, 2009 | 10:05 PM
acw's Avatar
acw
acw is infamous around these parts
I have a brand new 09 as well and I haven't experienced this. I would start by making sure the tires are inflated properly and have the alignment checked. Talk to the service dept, they will probably be more helpful than the sales team.
Arnaud
Old Nov 17, 2009 | 10:13 PM
shvt's Avatar
I'm glad to know the rattle (knocking, clicking) in the steering column is normal. I'll have to check to see if the airbag is rattling. Thanks for your help. Gotta get all these warranty or questions out of the way so I can enjoy the car. Seems like there is some sort of rattle in every car.
Old Nov 17, 2009 | 10:15 PM
shvt's Avatar
Arnaud
The tires are inflated properly. I have this thing with tire pressure. I brought a tire gauge to the dealership at pickup to make sure the tire pressure was correct before driving off. It was over inflated, of course. The alignment should be fine, drives straight.
Old Nov 17, 2009 | 11:04 PM
acw's Avatar
acw
The fact that your car drives straight doesn't mean the alignment is good. A car with too much toe, for example, could feel strange in corners yet drive straight. It is probably not the problem but I think it is still worth a shot. I guess you want the power steering inspected so you might as well ask them to check the alignment.
Old Nov 20, 2009 | 12:48 PM
SonicKrack's Avatar
SonicKrack is a glorious beacon of lightSonicKrack is a glorious beacon of lightSonicKrack is a glorious beacon of lightSonicKrack is a glorious beacon of lightSonicKrack is a glorious beacon of lightSonicKrack is a glorious beacon of light
After reading a couple of answers, I took out the AM receipts box and shuffled through some paperwork. It seems that every time the car went in for service or recall, a wheel alignment was also done. On the last recall repair, I called to find out the status and I was told that the mechanic is performing an alignment. Am I the only one getting alignments left and right??????
Old Nov 20, 2009 | 02:36 PM
rick-dms-'s Avatar
rick-dms- is infamous around these parts
the air bag rattle is a common issue, and also easy to remedy, if when placing your thumbs underneath the air bag and you can easily move it up in reference to the steering wheel and drops when released the chances are this will be your rattle, the very complex fix to this is fitting double sided foam strips the same as used to fit number plates is used betwen the airbag and steering wheel at three points which is quite evident once the airbag is removed, not a diy fix as airbags include an explosive charge so great care needs to be taken,
Old Nov 20, 2009 | 03:10 PM
SonicKrack - Had mine since 6/07 and not needed an alignment yet ~14k on ODO...
GetALife75
New Member Introductions
Sep 3, 2015 12:22 PM
Gus_Smedstad
Aug 29, 2015 04:43 PM
LiquidElephant
Aug 27, 2015 06:17 PM
AdPock
Ferrari
Aug 27, 2015 03:38 PM
DerekShiekhi
Other British Cars
Aug 19, 2015 05:25 PM
