Alarm System Codes
Old May 13, 2010 | 03:13 PM
GameTheory's Avatar
GameTheory is infamous around these parts
Alarm System Codes
My car recently started throwing codes for the alarm system. This is after starting it after a significant layoff of about a month or two. Since the car has been sitting idle, I don't see how or why it should be throwing codes - anyone with experience with this?
Old May 14, 2010 | 07:30 AM
Michael 996TT's Avatar
Michael 996TT is infamous around these parts
Mine is throwing one too "Alarm System Needs Service" - I pushed the "read" button and it goes away. Kinda hoping the SW fairy takes care of it one night. Seems everything is working - just the code goes on at start.
Old May 14, 2010 | 08:02 AM
gekko's Avatar
gekko is infamous around these partsgekko is infamous around these parts
I had this on my MY07 quite a few times and they ended up replacing the Alarm module.
Be curious to see the solution outside of the warranty period. Good Luck!
Old May 14, 2010 | 10:39 AM
stearnsn's Avatar
stearnsn is infamous around these parts
Mine did that too. The dealer traced it to a sensor in a rear wheel well that got wet. He replaced it an not problems since.
Old May 16, 2010 | 05:43 PM
markesq's Avatar
markesq has a spectacular aura aboutmarkesq has a spectacular aura about
Mine just went off!
Old Jun 2, 2010 | 03:31 PM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
I recently experienced a similar alarm warning; unfortunately, the car would not lock/unlock with the remote-had to use the key! Dealer traced the defect to the "sounder", i.e. siren module. Replaced under warranty and fine since...
Old Jun 3, 2010 | 07:42 AM
markesq's Avatar
That is what my dealer suspects. Can't get it over to dealer until August though.
Old Jul 2, 2010 | 01:28 PM
mightyanxious's Avatar
mightyanxious is infamous around these parts
Mine just started spitting this error also. Looks to be spreading rapidly.
Old Jul 2, 2010 | 03:11 PM
I can still push the "read" button and code goes away ... not a solution but works til I get to the dealer.
Old Jul 2, 2010 | 03:21 PM
Not so easy to get to the dealer and now out of warranty. What a PITA.
Old Jul 2, 2010 | 04:46 PM
markesq's Avatar
Even thought out of warranty, they may fix. I think there was a service bulletin.
Old Jul 6, 2010 | 11:27 AM
I called my dealer, no service bulletin. He said they were getting many of service requests for the code.
Old Jul 6, 2010 | 01:08 PM
markesq's Avatar
If it is out of warranty, I would still push them to fix. From what I understand, it is a very simple fix.
Old Jul 6, 2010 | 02:43 PM
Unfortunately, my original dealer is no longer an Aston dealer, so they don't have an incentive to do me any favors.
oddjob142
Aug 24, 2015 05:49 PM
